6513 Power showing Wrong Wattage
Bradford.berry
I just upgraded my power supply's from 2500Watts to 4000watts, however the show power still shows 2500watts.
how do i make the 6513 recongize the change?
I do have 250volts at 30 amps connected to each power supply.
Brad
system power redundancy mode = redundant
system power total =     2331.00 Watts (55.50 Amps @ 42V)
system power used =      1741.74 Watts (41.47 Amps @ 42V)
system power available =  589.26 Watts (14.03 Amps @ 42V)
                        Power-Capacity PS-Fan Output Oper
PS   Type               Watts   A @42V Status Status State
1    WS-CAC-2500W       2331.00 55.50  OK     OK     on
2    WS-CAC-2500W       2331.00 55.50  OK     OK     on
Bradford.berry
I had to hardboot the entire switch,  Power supplys now showing correct.
system power total =     3830.40 Watts (91.20 Amps @ 42V)
system power used =      1735.86 Watts (41.33 Amps @ 42V)
system power available = 2094.54 Watts (49.87 Amps @ 42V)
1    WS-CAC-4000W-US    3830.40 91.20  OK     OK     on
2    WS-CAC-4000W-US    3830.40 91.20  OK     OK     on
