Does Cisco supports Mobile IPV6 over IPSEC?
nehakulsum
I want to know Can we have the feature:- Mobile IPv6 over IPSec on cisco devices ?? If yes can anyone please provide me the link for the same.
Thanks in advance.
sumaiyausa
HI neha,
Should be supported.
REgards
neha.
sumaiyausa
HI neha,
regards,
sum.
kriska.martin
a few years later I am facing the same question and what I cannot find the answer
In almost every presentation I see it says that it will be supported in future, but when?
6deploy presentations says it will be in future
cisco.com site [http://www.cisco.com/en/US/technologies/collateral/tk648/tk872/tk373/technologies_white_paper_09186a00802219bc_ps6553_Products_White_Paper.html]
also says it will be done in future (actually it states it should be implemented in 2009) but the document hasn't been updated since then and there is no reference to IPSec wint Mobile IPv6 in new IOSes like 12.4T(22) or even 15.2 configuration guide does not seem to mention IPSec as an option
thank you for your reply in advance,
Martin
