6807 Nat problem
Daniel Davidson
Level 2
Level 2
We needed to change the IP of our many to one nat earlier today.  Relevant config lines below:
interface Vlan90
ip address 192.168.122.1 255.255.255.0
ip nat inside
interface Vlan281
ip address a.b.c.d 255.255.252.0
ip nat outside
ip flow monitor campus-public-monitor input
ip nat inside source list 101 interface Vlan281 overload
ip route 0.0.0.0 0.0.0.0 a.b.c.1
access-list 101 permit ip 192.168.122.0 0.0.0.255 any
This worked for over a year, then when one of my people changed int ouside nat IP to a.b.c.e, everything but pings stopped working.  So we can still ping google and our dns, but if you try to query google from our dns (in a.b.c.x) then it will not happen.  What are we doing wrong?  Apologies if this posted twice.
Julio E. Moisa
Have you tried to clean the translations?
clear ip nat translations *
Also the ACL could be a standard ACL
access-list 10 permit 192.168.122.0 0.0.0.255
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Reza Sharifi
Did you change provider?
Was your public facing IP changed?
casanavep
Level 7
Level 7
Have you tried:
- remove nat inside/outside form all interfaces
- delete the global nat policies
- reapply
something like...:
conf t
do clear ip nat trans *
y
int vlan 90
 no ip nat inside
int vlan 281
 no ip nat outside
no ip nat inside source list 101 interface Vlan281 overload
!   <-- give it a minute to chew on this, memory allocations to clear
int vlan 90
 ip nat inside
int vlan 281
 ip nat outside
end
