7600 packet loss problem
mohameddz
We have a directly connected 1 giga Ethernet link between  7600 ES+ 20xGE SFP/Cisco 7606-s port and a Cisco 3560, we have tried all combination of duplex and speed settings cat5/6 cable change; but we  are getting packet loss, please advise where could be the problem ?
New_Router_7600#sh module
Mod Ports Card Type                              Model              Serial No.
  1    0  4-subslot SPA Interface Processor-400  7600-SIP-400       JAB103400Y1
  2    0  4-subslot SPA Interface Processor-400  7600-SIP-400       JAB1034046Z
  3    0  2 port adapter Enhanced FlexWAN        WS-X6582-2PA       JAE1010XAZF
  4   20  7600 ES+                               7600-ES+20G3CXL    JAE1340KH0U
  5    2  Route Switch Processor 720 (Active)    RSP720-3CXL-GE     JAE1405388I
  6    2  Route Switch Processor 720 (Hot)       RSP720-3CXL-GE     SAL16052QWF
Mod MAC addresses                       Hw   Fw            Sw           Status
  1  0019.0699.da94 to 0019.0699.db13  2.3   Unknown       Unknown      PwrDown
  2  0019.0699.d114 to 0019.0699.d193  2.3   Unknown       Unknown      PwrDown
  3  0016.c827.d8e0 to 0016.c827.d91f  2.2   Unknown       Unknown      PwrDown
  4  1cdf.0fa3.3860 to 1cdf.0fa3.389f  1.3   12.2(33r)SRD  15.3(3)S     Ok
  5  001c.584f.1770 to 001c.584f.1773  5.9   12.2(33r)SRD  15.3(3)S     Ok
  6  0022.bdeb.80f0 to 0022.bdeb.80f3  5.13  12.2(33r)SR   15.3(3)S     Ok
Mod  Sub-Module                  Model              Serial       Hw     Status
  4  7600 ES+ DFC XL             7600-ES+3CXL       JAE14420TE8  1.1    Ok
  4  7600 ES+ 20xGE SFP          7600-ES+20G        JAE14420SBT  1.1    Ok
  5  Policy Feature Card 3       7600-PFC3CXL       JAE14053867  1.1    Ok
  5  C7600 MSFC4 Daughterboard   7600-MSFC4         JAE14052VSK  1.5    Ok
  6  Policy Feature Card 3       7600-PFC3CXL       SAL16020L3U  1.1    Ok
  6  C7600 MSFC4 Daughterboard   7600-MSFC4         SAL16063GXX  5.0    Ok
Mod  Online Diag Status
  1  Not Applicable
  2  Not Applicable
  3  Not Applicable
  4  Pass
  5  Pass
  6  Pass
router 7600:
New_Router_Core_7600#sh int gi4/11
GigabitEthernet4/11 is up, line protocol is up (connected)
  Hardware is X40G 1Gb 802.3, address is 6c41.6a26.f680 (bia 6c41.6a26.f680)
  Internet address is 2.2.2.1/30
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, clock source internal, media type is T
  input flow-control is off, output flow-control is on
  Clock mode is auto
  Last input 00:00:44, output 00:00:50, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  L2 Switched: ucast: 207725 pkt, 209829313 bytes - mcast: 784 pkt, 95112 bytes
  L3 in Switched: ucast: 975 pkt, 341306 bytes - mcast: 0 pkt, 0 bytes mcast
  L3 out Switched: ucast: 0 pkt, 0 bytes mcast: 0 pkt, 0 bytes
     16210406 packets input, 2397855914 bytes, 0 no buffer
     Received 53120 broadcasts (0 IP multicasts)
     0 watchdog, 0 multicast, 0 pause input
     204791 packets output, 209675529 bytes, 0 underruns
     0 output errors, 0 collisions, 3 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
switch 3560:
cs.ca1.net#sh int GigabitEthernet0/48
GigabitEthernet0/48 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 1c17.d324.ffe2 (bia 1c17.d324.ffe2)
  Internet address is 2.2.2.2/30
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:52, output 00:00:09, output hang never
     204759 packets input, 209667087 bytes, 0 no buffer
     Received 290 broadcasts (0 IP multicasts)
     0 watchdog, 285 multicast, 0 pause input
     16209321 packets output, 2397488447 bytes, 0 underruns
cs.ca1.net#ping 2.2.2.1 repeat 1000
Sending 1000, 100-byte ICMP Echos to 2.2.2.1, timeout is 2 seconds:
Success rate is 99 percent (993/1000), round-trip min/avg/max = 1/2/17 ms
best regard.
Benchabane Mohamed
7 Replies 7
Martin Hruby
Hello Mohamed
Do you have control-plane protection enabled on your 7600-series router?
Have a look at show policy-map control-plane on your 7600 to see if you have any pings denied by CoPP.
Best regards,
Martin
Hello Martin;
first thanks for your replay;
I did a show policy-map control-plane but i haven't any result
New_Router_Core_CA1_ALG#show policy-map control-plane
how can I enable control-plane protection ? or have you any other suggestion ?
best regard.
Benchabane Mohamed.
Hi Mohamed
I was just wondering whether you configured any policy there, because with control-plane protection you can limit inbound traffic like pings to prevent them from overrunning your device. So if the rate of incoming ICMP echo-requests exceeds a predefined threshold, you start dropping.
Here's a link with configuration details: http://www.cisco.com/c/en/us/td/docs/routers/7600/ios/15S/configuration/guide/7600_15_0s_book/dos.pdf
On some platforms it's enabled by default, on yours it's apparently not.
Do you have any QoS implemented on the link between the 7600 and the 3560? Something that would rate-limit traffic, or drop packets in case of congestion?
What happens when you try to send 500 pings at a time, then wait for a few seconds and then repeat? Do you still get drops?
Best regards,
Martin
Hi Martin,
We don't have any QoS implemented on the link between  the 7600 and the 3560, we have tried to send 500 pings at a time and wait and send others but we are getting a random packet loss, some times there is some packet loss some other time not. as you can notice on the below output:
New_Router_Core_CA1_ALG#ping 10.20.0.104 repeat 500 size 1500
Sending 500, 1500-byte ICMP Echos to 10.20.0.104, timeout is 2 seconds:
Success rate is 99 percent (499/500), round-trip min/avg/max = 1/1/20 ms
Success rate is 100 percent (500/500), round-trip min/avg/max = 1/1/4 ms
Success rate is 99 percent (499/500), round-trip min/avg/max = 1/1/8 ms
We had some doubt about the cisco 3560 switch, so we added a new link with another 4948 switch and have done some simultaneous pings tests to both 3560 and 4948 SW and we were very surprised that the packet loss occured at the same time ! do you any clue, thanks for your help
Best regards,
Mohamed
Hi Martin,
Do you have any ideas or recommendations or any suggestions please ?
Best Regards,
Mohamed.
Hello Mohamed
Would it be possible for you to post an output of show running-config from the 7600?
Best regards,
Martin
Hi Martin;
so happy to hear about you
here is the show run:
New_Router_Core_CA1_ALG#sh run
Building configuration...
Current configuration : 41555 bytes
! Last configuration change at 12:49:36 ALG Mon Aug 17 2015 by benchabane
! NVRAM config last updated at 13:12:40 ALG Mon Aug 17 2015 by benchabane
version 15.3
service counters max age 10
no service image-version efsu
hostname New_Router_Core_CA1_ALG
boot-start-marker
boot system bootdisk:c7600rsp72043-adventerprisek9-mz.153-3.S2.bin
boot system flash sup-bootdisk:c7600rsp72043-ipservicesk9-mz.152-4.S6.bin
boot-end-marker
logging buffered 16000
no logging console
no logging monitor
no aaa new-model
clock timezone ALG 1 0
ip domain retry 1
ip domain timeout 2
ip name-server x.x.x.x
ip name-server 8.8.8.8
l2tp-class l2-dyn
 authentication
 password 7 020F5C48145B73
 cookie size 8
no mpls ldp advertise-labels
mpls ldp advertise-labels for LP-MPLS
mls flow ip interface-full
no mls flow ipv6
mls cef error action reset
archive
 log config
  logging enable
  logging size 500
  notify syslog contenttype plaintext
  hidekeys
spanning-tree mode pvst
no power enable module 2
no power enable module 3
diagnostic bootup level minimal
redundancy
 main-cpu
  auto-sync running-config
 mode sso
vlan internal allocation policy ascending
vlan access-log ratelimit 2000
ip ssh version 2
track 1 ip sla 1 reachability
track 2 ip sla 2 reachability
track 3 ip sla 3 reachability
track 4 ip sla 4 reachability
track 5 ip sla 5 reachability
track 6 ip sla 6 reachability
track 7 ip sla 7 reachability
track 8 ip sla 8 reachability
track 19 ip sla 19 reachability
class-map match-all toto
 match any
class-map match-all 2class
 match any
pseudowire-class pw-dynamic
 encapsulation l2tpv3
 protocol l2tpv3 l2-dyn
 ip local interface Loopback220
interface Loopback0
 description used for management
 ip address 172.31.1.121 255.255.255.255
 ip ospf 1 area 1
interface Loopback1
 no ip address
 ip address 192.168.220.1 255.255.255.255
interface POS1/0/0
 no ip address
 shutdown
interface POS1/0/1
 no ip address
 shutdown
interface POS1/0/2
 no ip address
 shutdown
interface POS1/0/3
 no ip address
 shutdown
interface POS1/1/0
 no ip address
 shutdown
interface POS1/1/1
 no ip address
 shutdown
interface POS1/1/2
 no ip address
 shutdown
interface POS1/1/3
 no ip address
 shutdown
interface POS1/1/4
 no ip address
 shutdown
interface POS1/1/5
 no ip address
 shutdown
interface POS1/1/6
 no ip address
 shutdown
interface POS1/1/7
 no ip address
 shutdown
interface GigabitEthernet4/1
 mtu 3000
 ip address x.x.x.x 255.255.255.248
 ip router isis
 ip ospf 1 area 0
 speed 1000
 mpls ip
 isis network point-to-point
interface GigabitEthernet4/2
 ip router isis
 ip ospf 1 area 0
 speed auto
 mpls ip
interface GigabitEthernet4/3
 no ip address
 speed 1000
interface GigabitEthernet4/4
 no ip address
 shutdown
interface GigabitEthernet4/5
 no ip address
 shutdown
interface GigabitEthernet4/6
 no ip address
 shutdown
interface GigabitEthernet4/7
 no ip address
 shutdown
interface GigabitEthernet4/8
 no ip address
 shutdown
interface GigabitEthernet4/9
 no ip address
 ip ospf 1 area 1
 speed 1000
interface GigabitEthernet4/9.1
 encapsulation dot1Q 1 native
 ip address x.x.x.x 255.255.255.0
 ip policy route-map Tlemcen_to_Mad_London
 ip ospf 1 area 1
interface GigabitEthernet4/9.13
 encapsulation dot1Q 13
 ip address 172.31.1.233 255.255.255.252
interface GigabitEthernet4/9.14
 encapsulation dot1Q 14
 ip address x.x.x.x 255.255.255.224
interface GigabitEthernet4/9.15
 encapsulation dot1Q 15
 ip address 172.31.1.94 255.255.255.240
interface GigabitEthernet4/9.134
 encapsulation dot1Q 134
 ip address 172.31.1.54 255.255.255.248
 ip ospf 1 area 1
interface GigabitEthernet4/9.135
 encapsulation dot1Q 135
 ip address 172.31.1.78 255.255.255.248
 ip ospf 1 area 1
interface GigabitEthernet4/9.136
 encapsulation dot1Q 136
 ip address 172.31.1.158 255.255.255.248
 ip ospf 1 area 1
interface GigabitEthernet4/9.502
 encapsulation dot1Q 502
 ip address x.x.x.x 255.255.255.240
 ip ospf 1 area 1
interface GigabitEthernet4/9.509
 encapsulation dot1Q 509
 ip address 172.31.1.6 255.255.255.248
 ip ospf 1 area 1
interface GigabitEthernet4/9.511
 encapsulation dot1Q 511
 ip address 172.31.1.38 255.255.255.248
 ip router isis
 ip ospf 1 area 1
 mpls ip
interface GigabitEthernet4/9.516
 encapsulation dot1Q 516
 ip address 172.31.1.14 255.255.255.248
 ip ospf 1 area 1
interface GigabitEthernet4/9.517
 encapsulation dot1Q 517
 ip address 172.31.1.70 255.255.255.248
 ip ospf 1 area 1
interface GigabitEthernet4/9.518
 encapsulation dot1Q 518
 ip address 172.31.1.22 255.255.255.248
 ip ospf 1 area 1
interface GigabitEthernet4/9.519
 encapsulation dot1Q 519
 ip address 172.31.1.198 255.255.255.248
 ip ospf 1 area 1
interface GigabitEthernet4/9.523
 encapsulation dot1Q 523
 ip address 172.31.1.46 255.255.255.248
 ip ospf 1 area 1
interface GigabitEthernet4/9.524
 encapsulation dot1Q 524
 ip address 172.31.1.62 255.255.255.248
 ip ospf 1 area 1
interface GigabitEthernet4/9.525
 encapsulation dot1Q 525
 ip address 172.31.1.150 255.255.255.248
 ip ospf 1 area 1
interface GigabitEthernet4/9.526
 bandwidth 1000000
 encapsulation dot1Q 526
 ip address 172.31.1.101 255.255.255.248
 ip ospf 1 area 1
 ip ospf cost 30
interface GigabitEthernet4/9.610
 encapsulation dot1Q 610
 ip address 172.31.1.30 255.255.255.248
 ip ospf 1 area 1
interface GigabitEthernet4/9.615
 encapsulation dot1Q 615
 ip address 172.31.1.129 255.255.255.248
 ip ospf 1 area 1
interface GigabitEthernet4/9.700
 encapsulation dot1Q 700
 ip address 172.31.1.225 255.255.255.248
 ip ospf 1 area 1
interface GigabitEthernet4/10
 ip address 10.12.13.1 255.255.255.0
interface GigabitEthernet4/11
 ip address 2.2.2.1 255.255.255.252
 speed 1000
interface GigabitEthernet4/12
 no ip address
 shutdown
interface GigabitEthernet4/13
 no ip address
 shutdown
interface GigabitEthernet4/14
 no ip address
 shutdown
interface GigabitEthernet4/15
 no ip address
 shutdown
interface GigabitEthernet4/16
 no ip address
 shutdown
interface GigabitEthernet4/17
 no ip address
 shutdown
interface GigabitEthernet4/18
 no ip address
 shutdown
interface GigabitEthernet4/19
 no ip address
 shutdown
interface GigabitEthernet4/20
 no ip address
 shutdown
interface GigabitEthernet5/1
 no ip address
 shutdown
interface GigabitEthernet5/2
 ip address 5.5.5.1 255.255.255.0
 media-type rj45
 speed 1000
 duplex full
interface GigabitEthernet6/1
 no ip address
 shutdown
interface GigabitEthernet6/2
 no ip address
 shutdown
interface Vlan1
 no ip address
 shutdown
router eigrp 220
 network 172.16.44.18 0.0.0.0
 network 172.31.1.38 0.0.0.0
 distance eigrp 254 254
 distance 255 0.0.0.0 255.255.255.255 Not-MPLS-LP
router ospf 1
 router-id 1.1.1.1
 area 1 nssa no-redistribution no-summary
 redistribute static metric-type 1 subnets route-map Redistrib_Static
router isis
 net 49.0001.4444.4444.4444.00
 metric-style wide
router bgp 36891
 bgp log-neighbor-changes
 no bgp default ipv4-unicast
 neighbor 192.168.220.2 remote-as 36891
 neighbor 192.168.220.2 update-source Loopback220
 neighbor 192.168.220.3 remote-as 36891
 neighbor 192.168.220.3 update-source Loopback220
 neighbor 192.168.220.4 remote-as 36891
 neighbor 192.168.220.4 update-source Loopback220
 address-family ipv4
 exit-address-family
 address-family vpnv4
  neighbor 192.168.220.2 activate
  neighbor 192.168.220.2 send-community both
  neighbor 192.168.220.2 route-reflector-client
  neighbor 192.168.220.3 activate
  neighbor 192.168.220.3 send-community both
  neighbor 192.168.220.3 route-reflector-client
  neighbor 192.168.220.4 activate
  neighbor 192.168.220.4 send-community both
  neighbor 192.168.220.4 route-reflector-client
 exit-address-family
ip forward-protocol nd
no ip http server
no ip http secure-server
ip prefix-list Def_Only seq 5 permit 0.0.0.0/0
ip sla 1
 icmp-echo x.x.x.x source-interface GigabitEthernet4/1
ip sla schedule 1 life forever start-time now
ip sla 3
 icmp-echo x.x.x.x
 timeout 20000
ip sla schedule 3 life forever start-time now
ip sla 4
 icmp-echo x.x.x.x
ip sla schedule 4 life forever start-time now
ip sla 5
 icmp-echo x.x.x.x
ip sla schedule 5 life forever start-time now
ip sla 6
 icmp-echo x.x.x.x
ip sla schedule 6 life forever start-time now
ip sla 7
 icmp-echo x.x.x.x
ip sla schedule 7 life forever start-time now
ip sla 8
 icmp-echo x.x.x.x
ip sla schedule 8 life forever start-time now
ip sla 9
 icmp-echo x.x.x.x
ip sla 19
 icmp-echo x.x.x.x
ip sla schedule 19 life forever start-time now
logging alarm informational
logging trap notifications
route-map Redistrib_Static permit 10
 match ip address Redistrib_Static
route-map Redistrib_Static deny 20
route-map Def_Only permit 10
 match ip address prefix-list Def_Only
route-map Tlemcen_to_London permit 10
 match ip address Tlemcen_to_Mad_London
 set ip next-hop x.x.x.x
mpls ldp router-id Loopback220 force
control-plane
line con 0
 logging synchronous
 login local
 stopbits 1
line vty 0 4
 logging synchronous
 login local
 transport input telnet ssh
exception crashinfo buffersize 80
ntp source GigabitEthernet4/9
ntp update-calendar
ntp server x.x.x.x
ntp server x.x.x.x
end
ther is a lot of static route that i didn't post in the show
best regard
Mohamed.
