Nexus 7000: No SNMP DOM data
peteroseneff
Hi everyone,
While polling the host using snmpwalk and 1.3.6.1.2.1.47.1.1.1.1.7 OID got nothing interesting. But I need to get this info somehow:
show interface ethernet 3/46 transceiver details
Ethernet3/46
    transceiver is present
    type is 10Gbase-ER
    name is CISCO-OPNEXT,INC
    part number is TRS7050EN-S103
    revision is 0012
    serial number is ONT173604QB
    nominal bitrate is 10300 MBit/sec
    Link length supported for 9/125um fiber is 40 km
    cisco id is --
    cisco extended id number is 4
           SFP Detail Diagnostics Information (internal calibration)
                Current              Alarms                  Warnings
                Measurement     High        Low         High          Low
  Temperature   33.15 C        75.00 C     -5.00 C     70.00 C        0.00 C
  Voltage        3.30 V         3.63 V      2.97 V      3.46 V        3.13 V
  Current       46.98 mA      120.00 mA    20.00 mA   112.00 mA      24.00 mA
  Tx Power       0.67 dBm       6.99 dBm   -8.72 dBm    3.99 dBm     -4.71 dBm
  Rx Power     -17.69 dBm  -    1.99 dBm  -20.00 dBm   -1.00 dBm    -15.85 dBm
  Transmit Fault Count = 0
  Note: ++  high-alarm; +  high-warning; --  low-alarm; -  low-warning
  *** SFP diagnostics data may be invalid!  ***
Could you guys point me out regarding the right SNMP OID?
Thanks!
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Documents: http://www.cisco.com/en/US/products/ps9372/tsd_products_support_series_home.html
Copyright (c) 2002-2013, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained in this software are
owned by other third parties and used and distributed under
license. Certain components of this software are licensed under
the GNU General Public License (GPL) version 2.0 or the GNU
Lesser General Public License (LGPL) Version 2.1. A copy of each
such license is available at
http://www.opensource.org/licenses/gpl-2.0.php and
http://www.opensource.org/licenses/lgpl-2.1.php
Software
  BIOS:      version 2.12.0
  kickstart: version 6.1(4a)
  system:    version 6.1(4a)
  BIOS compile time:       05/29/2013
  kickstart image file is: bootflash:///n7000-s2-kickstart-npe.6.1.4a.bin
  kickstart compile time:  12/25/2020 12:00:00 [09/26/2013 06:22:01]
  system image file is:    bootflash:///n7000-s2-dk9-npe.6.1.4a.bin
  system compile time:     7/8/2013 19:00:00 [09/26/2013 08:08:40]
Hardware
  cisco Nexus7000 C7004 (4 Slot) Chassis ("Supervisor module-2")
  Intel(R) Xeon(R) CPU         with 12225160 kB of memory.
peteroseneff
Just guessing may be NX-OS 6.1(4a) doesnt support this feature ( get transceiver  TX/RX Power data via SNMP)? Catalyst C3750 switches for instance do that with no problem btw.
snmpwalk -c XXXXX -v2c XX.XX.XX.XX 1.3.6.1.2.1.47.1.1.1.1.7
Cannot find module (IP-MIB): At line 0 in (none)
Cannot find module (IF-MIB): At line 0 in (none)
Cannot find module (TCP-MIB): At line 0 in (none)
Cannot find module (UDP-MIB): At line 0 in (none)
Cannot find module (HOST-RESOURCES-MIB): At line 0 in (none)
Cannot find module (SNMPv2-MIB): At line 0 in (none)
Cannot find module (SNMPv2-SMI): At line 0 in (none)
Cannot find module (NOTIFICATION-LOG-MIB): At line 0 in (none)
Cannot find module (UCD-SNMP-MIB): At line 0 in (none)
Cannot find module (UCD-DEMO-MIB): At line 0 in (none)
Cannot find module (SNMP-TARGET-MIB): At line 0 in (none)
Cannot find module (NET-SNMP-AGENT-MIB): At line 0 in (none)
Cannot find module (DISMAN-EVENT-MIB): At line 0 in (none)
Cannot find module (SNMP-VIEW-BASED-ACM-MIB): At line 0 in (none)
Cannot find module (SNMP-COMMUNITY-MIB): At line 0 in (none)
Cannot find module (UCD-DLMOD-MIB): At line 0 in (none)
Cannot find module (SNMP-FRAMEWORK-MIB): At line 0 in (none)
Cannot find module (SNMP-MPD-MIB): At line 0 in (none)
Cannot find module (SNMP-USER-BASED-SM-MIB): At line 0 in (none)
Cannot find module (SNMP-NOTIFICATION-MIB): At line 0 in (none)
Cannot find module (SNMPv2-TM): At line 0 in (none)
iso.3.6.1.2.1.47.1.1.1.1.7.10 = STRING: "Fabric Stack Root"
iso.3.6.1.2.1.47.1.1.1.1.7.22 = STRING: "Supervisor module-2"
iso.3.6.1.2.1.47.1.1.1.1.7.23 = STRING: "Supervisor module-2"
Is it OK for snmpwalk to ignor the 'Cannot find module' error?
Bug CSCty93934
Description
Symptom:
Nexus does not have entityPhysical Indexes for a slot/port combination which can be used to query entitySensorValue/entityThreshold values.
This leads to inability to retrieve DOM statistics from SFP transceivers in easy way.
