7600 process high cpu
etn
Community Member
i try newest ios 15.1(3)S0a and 12.2(33)SRE
in both case some times i obtain lowing traffic on interface and highest cpu - to 100%
after clear cef linicard i obtain growing traffic and cpu 0%
#sh proc cpu s
CPU utilization for five seconds: 87%/83%; one minute: 91%; five minutes: 96%
PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
   7     1711512       87883      19474  4.06%  0.84%  0.89%   0 Check heaps
245        5688    10115351          0  0.16%  0.12%  0.13%   0 Ethernet Msec Ti
210        2276     2538856          0  0.08%  0.02%  0.01%   0 IP ARP Retry Age
211       44772      267882        167  0.08%  0.04%  0.05%   0 IP Input
244         428      326057          1  0.08%  0.00%  0.00%   0 Ethernet Timer C
#clear cef linecard
#sh proc cpu s
CPU utilization for five seconds: 0%/0%; one minute: 3%; five minutes: 3%
157       36588        1511      24214  0.23%  0.02%  0.00%   0 Per-minute Jobs
346      110540       43940       2515  0.15%  0.06%  0.05%   0 HIDDEN VLAN Proc
211       45600      280259        162  0.07%  0.04%  0.03%   0 IP Input
18 Replies 18
rsimoni
Hi Alex,
what do you mean by "i obtain lowing traffic on interface" ? Do you see drops? Can you document them?
how often do you see the problem?
how many boxes are affected?
Next time you see the problem can you take the following BEFORE clearing CEF.
show module
show version
show process cpu sorted
show ibc brief
show cef line
after you clear cef you wait 2-3 minutes and then
show process cpu s
show ibc
show cef line
Let's see if I can get something useful from those outputs or else, as I wrote on the other thread, you'd better open a TAC case for deeper investigation.
Riccardo
etn
Community Member
Hi, Riccardo
problem is vary irregular - can be many times per day or no per week
any parameters no chage befor and after command clear
do not understand - what is box ?
#sh mod
Mod Ports Card Type                              Model              Serial No.
  1    2  Route Switch Processor 720 (Active)    RSP720-3CXL-GE
  2    4  CEF720 4 port 10-Gigabit Ethernet      WS-X6704-10GE
  3    4  CEF720 4 port 10-Gigabit Ethernet      WS-X6704-10GE
Mod MAC addresses                       Hw    Fw           Sw           Status
  1     5.7   12.2(33r)SRB 12.2(33)SRE5 Ok
  2     2.7   12.2(14r)S5  12.2(33)SRE5 Ok
  3     2.3   12.2(14r)S5  12.2(33)SRE5 Ok
Mod  Sub-Module                  Model              Serial       Hw     Status
  1  Policy Feature Card 3       7600-PFC3CXL         1.2    Ok
  1  C7600 MSFC4 Daughterboard   7600-MSFC4           1.1    Ok
  2  Centralized Forwarding Card WS-F6700-CFC         4.1    Ok
  3  Centralized Forwarding Card WS-F6700-CFC         4.1    Ok
sh ver
Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-IPSERVICESK9-M), Version 12.2(33)SRE5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 15-Sep-11 01:11 by prod_rel_team
ROM: System Bootstrap, Version 12.2(33r)SRB4, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-IPSERVICESK9-M), Version 12.2(33)SRE5, RELEASE SOFTWARE (fc1)
OnePower uptime is 5 days, 3 hours, 39 minutes
Uptime for this control processor is 5 days, 3 hours, 37 minutes
System returned to ROM by reload (SP by reload)
System restarted at 11:35:01 YEKST Fri Oct 7 2011
System image file is "bootdisk:/c7600rsp72043-ipservicesk9-mz.122-33.SRE5.bin"
Last reload type: Normal Reload
Cisco CISCO7604 (M8500) processor (revision 2.0) with 1900544K/131072K bytes of memory.
Processor board ID FOX1326GDYU
BASEBOARD: RSP720
CPU: MPC8548_E, Version: 2.0, (0x80390020)
CORE: E500, Version: 2.0, (0x80210020)
CPU:1200MHz, CCB:400MHz, DDR:200MHz,
L1:    D-cache 32 kB enabled
        I-cache 32 kB enabled
Last reset from power-on
9 Virtual Ethernet interfaces
2 Gigabit Ethernet interfaces
8 Ten Gigabit Ethernet interfaces
3964K bytes of non-volatile configuration memory.
507024K bytes of Internal ATA PCMCIA card (Sector size 512 bytes).
show process cpu sorted | e 0.00%  0.00%  0.00%
CPU utilization for five seconds: 3%/2%; one minute: 5%; five minutes: 5%
367       97620     1475871         66  0.07%  0.01%  0.00%   0 BGP I/O
306        3900     2421176          1  0.07%  0.02%  0.01%   0 TCP Timer
  29       88848      674355        131  0.07%  0.01%  0.00%   0 IPC Seat Manager
438      210188     2401185         87  0.07%  0.03%  0.02%   0 Port manager per
  47         244      444522          0  0.07%  0.00%  0.00%   0 GraphIt
245        6396    54021009          0  0.07%  0.08%  0.07%   0 Ethernet Msec Ti
248        2900    13539680          0  0.07%  0.01%  0.00%   0 IPAM Manager
  59          80       44615          1  0.07%  0.00%  0.00%   0 Net Background
   7     5529260      295431      18715  0.00%  0.90%  1.02%   0 Check heaps
   2       17712       89010        198  0.00%  0.01%  0.00%   0 Load Meter
  73        3040        4847        627  0.00%  0.01%  0.00%   1 Virtual Exec
210        2496    13539674          0  0.00%  0.02%  0.00%   0 IP ARP Retry Age
211      200952     2778465         72  0.00%  0.05%  0.07%   0 IP Input
294      116484      358092        325  0.00%  0.02%  0.02%   0 XDR mcast
346      254440      222523       1143  0.00%  0.05%  0.05%   0 HIDDEN VLAN Proc
444      878864     2088940        420  0.00%  0.05%  0.07%   0 BGP Router
499     7460608       36888     202250  0.00%  0.87%  1.22%   0 BGP Scanner
show cef line
Slot   Flags
1/0    up
VRF IPv4:Default, 368765 routes
Slot    I/Fs State    Flags
1/0        6 Active   sync, table-up
VRF IPv6:Default, 2 routes
1/0        0 Active   sync, table-up
show ibc brief
Interface information:
        Interface IBC0/0(idb 0x150A73E8)
        5 minute rx rate 11585000 bits/sec, 1529 packets/sec
        5 minute tx rate 23542000 bits/sec, 3059 packets/sec
        2970488354 packets input, 2217147403408 bytes
        2970394762 broadcasts received
        2969724007 packets output, 2214293033620 bytes
        66688948 broadcasts sent
        0 Bridge Packet loopback drops
        2967333578 Packets CEF Switched, 0 Packets Fast Switched
        0 Packets SLB Switched, 0 Packets CWAN Switched
        Label switched pkts dropped: 0    Pkts dropped during dma: 1097
        Invalid pkts dropped: 0    Pkts dropped(not cwan consumed): 0
        IPSEC pkts: 4553242
        Xconnect pkts processed: 0, dropped: 0
        Xconnect pkt reflection drops: 0
        Total paks copied for process level 0
        Total short paks sent in route cache 438681305
        Total throttle drops 0    Input queue drops 0
        total spd packets classified (1269812 low, 1627108 medium, 48840 high)
        total spd packets dropped (1097 low, 0 medium, 0 high)
        spd prio pkts allowed in due to selective throttling (0 med, 0 high)
        IBC resets   = 1; last at 23:35:59.527 YEKST Sat Jul 15 2000
rsimoni
Alex,
have you rated/closed the other question yet?
Riccardo
nkarpysh
Hi Alex,
As we can see High CPU is due to interrupts:
Value after /  - 83% is interrupts which are used to send traffi to CPU. So for some reason some traffic getting software switched instead of being HW switched.
As clear cef solves the issue I guess some CEF/GRT mismatch is happening. Possibly some CEF routes are lost making router to send prefixes for those lost entries to the CPU.
First of all we need to understand what are those packets.
Best tool to sniff cpu is netdr. It is safe to use with High CPU
Configure it when you see CPU going up again:
- debug netdr capture rx (let it run few seconds)
- show netdr capture
http://www.cisco.com/en/US/docs/routers/7600/ios/15S/configuration/guide/dos.html#wp1163918
You will see the packets coming in CPU. And then you will be able to check if you have CEF entries for destination ips.
That will give more clue of possible root cause.
Nik
HTH,
Niko
etn
Community Member
Hi, Nikolay
CPU now grow
sh proc cpu s
CPU utilization for five seconds: 41%/40%; one minute: 44%; five minutes: 43%
244        1784    55116403          0  0.15%  0.10%  0.10%   0 Ethernet Msec Ti
498      388716      566545        686  0.07%  0.04%  0.06%   0 BGP Task
  12       28076      190864        147  0.07%  0.00%  0.00%   0 ARP Input
   4           0         174          0  0.00%  0.00%  0.00%   0 Retransmission o
   5           0           3          0  0.00%  0.00%  0.00%   0 IPC ISSU Dispatc
   6           0           1          0  0.00%  0.00%  0.00%   0 PF Redun ICC Req
i do not see that
all are show command  give me picture than all traffic goes throw CEF
show ibc brief
        5 minute rx rate 304992000 bits/sec, 48826 packets/sec
        5 minute tx rate 621909000 bits/sec, 97638 packets/sec
        4090902684 packets input, 2930329196392 bytes
        4090652673 broadcasts received
        4090450834 packets output, 2926531746102 bytes
        107393 broadcasts sent
        4088722150 Packets CEF Switched, 0 Packets Fast Switched
        Label switched pkts dropped: 0    Pkts dropped during dma: 0
        IPSEC pkts: 5277877
        Total short paks sent in route cache 536662685
        total spd packets classified (787923 low, 1116063 medium, 54980 high)
        total spd packets dropped (0 low, 0 medium, 0 high)
        IBC resets   = 1; last at 10:53:29.327 YEKST Fri Oct 7 2011
nkarpysh
Hi Alex,
Actually these values:
41%/40% mean that CPU is busy on 41% of resources and 40% of CPU taken by traffic and only 1% by SW processes (STP, telnet, etc.). I don't mean that all traffic hitting the CPU. It may be just some - but that it causing the spike. As I advised previously you need to understand what is the traffic hitting the CPU.
You can do either CPU SPAN or netdr as suggested before.
Nik
HTH,
Niko
Alexandr Gurbo
Frequent Visitor
Frequent Visitor
Hello Alex,
Do you found a problem?
I have the same problem on SRE6 and SRE7a.
Same problem here with SRE6, RSP720-3CXL
CPU load in interrupts grows to 50-80%, "clear cef linecard" helps for random time from hours to days.
It is one of two almost identical boxes, configuration also almost the same. On another box no such problem.
show netdr captured gives lots of normal packets, which are supposed to be routed in hardware but
for some reason spontaneously hit CPU.
If anybody has a solution, please let me know. Thanks!
Nicholas Oliver
Alex,
Just to reiterate what Nikolay said before, CPU utilization on an RSP720 or a SUP720 under interrupts, as you see, is generally due to punted traffic.  There will be no single solution for this type of problem as each situation is unique.  The question that must be answered in a situation like this is WHY is the traffic being punted?  The key to answering this question is always figuring out what that traffic is.  A netdr capture or a span of the inband channel will help in this process, but this is not an easy process to track down why it is occurring.  In your situation it sounds like we may be dealing with an issue in which the CEF forwarding table is either too large, and this is resulting in punts, or is somehow becoming stale and the clear allows it to be reprogrammed.  This issue will not be easily troubleshot through posts to the support forums, though we can certainly help if you prefer to handle the issue in this way.  My suggestion would be that you open a case with the TAC when this issue is being seen so that we can have a live view of what is being punted and assist in determining why.
If you open a case, the best tech/subtech to select for this type of problem is:
TECH: LAN Switching
SUBTECH: Cat 6000, 6500 Troubleshooting High CPU Running IOS
PROBLEM CODE: Error Messages, Logs, Debugs
The same answer goes for [email protected], if you are actively seeing this problem engaging the TAC will get you the fastest resolution for this type of issue.  If you would prefer to go through the support forums, we will need to see the packets being punted through a netdr capture as Nikolay described above.
-Nick
sbr
Visitor
6 days ago issued command, found from some internet forum discusstion "remote command switch test mls cef tcam-shadow off" and CPU load is still at normal 2-5%.
Alex,
Do you see anything in the output of the 'show mls cef inconsistency' or 'show mls cef logg' outputs?  I can't come up with a valid reason why you should have to disable tcam-shadowing in order for the punts to stop.  I expect there's a problem that is causing an inconsistency and resulting in punts to the RP CPU.  I would not be content to leave it as is, and would be interested in investigating further the reason for these punts.
-Nick
show mls cef exception status is/was always FALSE, I've checked it while high CPU load.
show mls cef logg is empty
#show mls cef inconsistency
Consistency Check Count       : 52973
TCAM Consistency Check Errors : 0
SSRAM Consistency Check Errors : 0
Still waiting for high CPU load event after reload 6 days ago except single one minutes right after reboot, but it is gone after (or maybe it was coincidence) "remote command switch test mls cef tcam-shadow off".
Alex,
The exception status would be an indication that we had filled the TCAM and had to punt everything.  My suspicion is that we are not in an exception state where we are punting everything, but rather that there is an inconsistency causing certain types of traffic to be punted, when they shouldn't.  It is possible that disabling tcam shadowing is avoiding this issue, by going directly to the source, rather than relying on the shadow copy to determine if forwarding can take place without a punt.
-Nick
bo2112260285
Community Member
Dear All,
Please kindly advise how to use "remote command switch test mls cef tcam-shadow off" for this case. I go command on router but there're not any test option. The below for your reference
remote command switch ?
  LINE  Remote command string
Best Regards
