7600 process XDR LC PRIO cpu 100%
etn
i have
Route Switch Processor 720    RSP720-3CXL-GE
CEF720 4 port 10-Gigabit Ethernet      WS-X6704-10GE
+ ios 12.2(33)SRE2
the same on ios c7600rsp72043_rp-IPSERVICES-M), Version 15.1(3)S0a
some times
rem com sw sh proc cpu s
CPU utilization for five seconds: 7%/0%; one minute: 6%; five minutes: 6%
PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
277           8        1912          4 100.00% 42.05% 40.82%   0 XDR LC PRIO Crit
135      417280     2123114        196  3.83%  3.80%  3.83%   0 slcp process
far CPU utilization RP go to 100%
i do
clear cef linecard
CPU utilization go to 0%
some times per week
what is wrong ?
6 Replies 6
etn
set up new ios c7600rsp72043_rp-IPSERVICESK9-M), Version 12.2(33)SRE5
situation do not change
rsimoni
Hi Alex,
quick notation first; when you check "remote command switch show process cpu" you are actually checking the CPU utilization on the SP not on the RP.
Beside that what you see is just a cosmetic issue (wrong cpu utilization reading) documented in
CSCtf55740    XDR LC Prio Crit process showing 5sec CPU usage at 100%
Symptom:
     High CPU utilization reported due to "XDR LC Prio Crit" process.
     Conditions:
     This issue is seen in the Switch Processor (SP) of Sup720 engines running
  12.2(33)SRE1 release.
     CPU utilization for the above mentioned process is not reported correctly.
     for example, the switch reports the total CPU usage as 3%, while the CPU
  usage for this specific process as 100% for 5sec and 49% for 5min Avg.
     7600A#remote login switch
     7600A-sp#show process cpu sorted 1min
     CPU utilization for five seconds: 3%/0%; one minute: 3%; five minutes: 3%
      288         352        5746         61 100.00% 52.13% 49.63%   0 XDR LC
  PRIO Crit
      177      699848      108108       6473  1.51%  1.51%  1.51%   0 Vlan
  Statistics
      180      223304       34033       6561  1.03%  0.47%  0.46%   0 TYFIB Table
  Mana
      136       48812     6752273          7  0.47%  0.45%  0.45%   0 slcp process
      376      102932       57572       1787  0.00%  0.27%  0.27%   0 Env Poll
     As the CPU usage reported for this process is NOT correct, it should NOT
  have any impact to the performance. This bug is cosmetic.
     Workaround:
     None.
     This issue is cosmetic.
Since it is cosmetic it will not be fixed in SRE train but only in 15.1S. Check the bug to see which exact cco rebuild will contain the fix. In the meantime don't be worried
Riccardo
Hi, Riccardo !
may be "This bug is cosmetic" in sp on ios sre
BUT i try newest ios 15.1(3)S0a and obtain low traffic on interface in highest cpu - to 100%
after clear cef linicard i obtain growing traffic and cpu 0%
#sh proc cpu s
CPU utilization for five seconds: 87%/83%; one minute: 91%; five minutes: 96%
   7     1711512       87883      19474  4.06%  0.84%  0.89%   0 Check heaps
245        5688    10115351          0  0.16%  0.12%  0.13%   0 Ethernet Msec Ti
210        2276     2538856          0  0.08%  0.02%  0.01%   0 IP ARP Retry Age
211       44772      267882        167  0.08%  0.04%  0.05%   0 IP Input
244         428      326057          1  0.08%  0.00%  0.00%   0 Ethernet Timer C
#clear cef linecard
#sh proc cpu s
CPU utilization for five seconds: 0%/0%; one minute: 3%; five minutes: 3%
157       36588        1511      24214  0.23%  0.02%  0.00%   0 Per-minute Jobs
346      110540       43940       2515  0.15%  0.06%  0.05%   0 HIDDEN VLAN Proc
211       45600      280259        162  0.07%  0.04%  0.03%   0 IP Input
rsimoni
Hi Alex,
I think that the SP CPU utilization is not related to what you are seeing now, which is RP CPU utilization in interrupts (no process is really going high but it is high CPU at interrupt level).
The fact that it goes away after you clear cef, which implies a TCAM reprogramming, might indicate some some kind of wrong/missing hardware programming on your PFC/DFC.
You might want to check with the TAC; anyway it is not related to 'XDR LC Prio Crit' going high on the SP.
Riccardo
ok, thanx
i create other theme
rsimoni
ok,
please rate/close this question then
Riccardo
