7613 continually repeated the same message
sdurn
Level 2
Level 2
I have a cisco 7613 with version c7600s72033-adventerprisek9-mz.122-33.SRC.bin
and since a few days displayed the following loggings:
Dec 13 13:25:17.137: %IPC-5-WATERMARK: 1425 messages pending in rcv for the port (2170000.0) from source seat 10000
Dec 13 13:25:57.169: %IPC-5-WATERMARK: 1425 messages pending in rcv for the port (2170000.0) from source seat 10000
Dec 13 13:26:37.264: %IPC-5-WATERMARK: 1425 messages pending in rcv for the port (2170000.0) from source seat 10000
Dec 13 13:27:17.296: %IPC-5-WATERMARK: 1425 messages pending in rcv for the port (2170000.0) from source seat 10000
Dec 13 13:27:57.412: %IPC-5-WATERMARK: 1425 messages pending in rcv for the port (2170000.0) from source seat 10000
Dec 13 13:28:37.552: %IPC-5-WATERMARK: 1425 messages pending in rcv for the port (2170000.0) from source seat 10000
Dec 13 13:29:17.583: %IPC-5-WATERMARK: 1425 messages pending in rcv for the port (2170000.0) from source seat 10000
I have reviewed the bugs but it seems that this version is not affected. I have also seen that could be the cpu but if you have high peaks, errors also occur with low CPU. What could be the reason?
thanks!
Yudong Wu
Level 11
Level 11
Might hit the following bug
CSCso14087
thanks for the info, but the bug you mention is related to messages pending in rcv for the port (2160000.0). And in my case the port is 2170000.0?
Well, I think it might be related since
1. in release notes, it mentioned port number END with ".0"
2. I saw several cases where "2170000.0" was seen referred to this bug as well.
fzamora
You're hitting CSCso14087
Franco
