(7G) Links Port-channel output Drop on Cisco 3560 --- Cisco 4500 Ether-channel
Dr.X
Level 2
Level 2
Hello Folks ,
We have an L2 trunk between cisco 3560 and cisco 4500.
we have 7 ports bundled in that channel.
we have both sides flow control disabled in/out
real traffic can reach to 5.5 G, but we still see output Drops only on 3560.
At 4500 we don't see any Drops at all in Etherchannel.
Both sides have( ip-src-dst) hashing algorithms for load balancing.
I searched almost all posts in the forum but not able to find something can help me.
i tested PPS and switch limitations, all is normal and under thresholds.
I'm just wondering does ether channel port like 7 G with real traffic 4-5.5 G loaded require different settings?
could be a bug? why is it only on one side of ether channel not on both of them ?!!
below show commands :
1- Cisco 3560 :
3560G#sh etherchannel summary
Flags: D - down P - bundled in port-channel
I - stand-alone s - suspended
H - Hot-standby (LACP only)
R - Layer3 S - Layer2
U - in use f - failed to allocate aggregator
M - not in use, minimum links not met
u - unsuitable for bundling
w - waiting to be aggregated
d - default port
Number of channel-groups in use: 5
Number of aggregators: 5
Group Port-channel Protocol Ports
45 Po45(SU) - Gi0/6(P) Gi0/7(P) Gi0/24(P)
Gi0/32(P) Gi0/34(P) Gi0/45(P)
Gi0/48(P)
3560G#sh run int port-channel 45
Building configuration...
Current configuration : 124 bytes
interface Port-channel45
description 3560--4500 Bundle
switchport mode trunk
end
3560G#sh int port-channel 45
Port-channel45 is up, line protocol is up (connected)
Hardware is EtherChannel, address is 0023.ea72.ba06 (bia 0023.ea72.ba06)
Description: 3560--4500 Bundle
MTU 1500 bytes, BW 7000000 Kbit, DLY 10 usec,
reliability 255/255, txload 123/255, rxload 196/255
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, link type is auto, media type is unknown
input flow-control is off, output flow-control is unsupported
Members in this channel: Gi0/6 Gi0/7 Gi0/24 Gi0/32 Gi0/34 Gi0/45 Gi0/48
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 01:45:41
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 71866200
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 5405805000 bits/sec, 673407 packets/sec
5 minute output rate 3398399000 bits/sec, 520771 packets/sec
4072242825 packets input, 4102195296979 bytes, 0 no buffer
Received 842862805 broadcasts (150897 multicasts)
2 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 150897 multicast, 0 pause input
3185468252 packets output, 2632031579409 bytes, 0 underruns
3560G#sh etherchannel load-balance
EtherChannel Load-Balancing Configuration:
src-dst-ip
EtherChannel Load-Balancing Addresses Used Per-Protocol:
Non-IP: Source XOR Destination MAC address
IPv4: Source XOR Destination IP address
IPv6: Source XOR Destination IP address
3560G#sh ve
3560G#sh version
Cisco IOS Software, C3560 Software (C3560-IPSERVICESK9-M), Version 12.2(53)SE2, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Wed 21-Apr-10 05:33 by prod_rel_team
Image text-base: 0x01000000, data-base: 0x02E00000
ROM: Bootstrap program is C3560 boot loader
BOOTLDR: C3560 Boot Loader (C3560-HBOOT-M) Version 12.2(44)SE5, RELEASE SOFTWARE (fc1)
3560G uptime is 1 year, 27 weeks, 7 hours, 42 minutes
System image file is "flash:/c3560-ipservicesk9-mz.122-53.SE2.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C3560G-48TS (PowerPC405) processor (revision D0) with 131072K bytes of memory.
Processor board ID FOC1245W1F1
Last reset from power-on
21 Virtual Ethernet interfaces
52 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:23:EA:72:BA:00
Motherboard assembly number : 73-10214-04
Power supply part number : 341-0107-01
Motherboard serial number : FOC12450UNW
Power supply serial number : AZS124310CD
Model revision number : D0
Motherboard revision number : C0
Model number : WS-C3560G-48TS-S
System serial number : FOC1245W1F1
Top Assembly Part Number : 800-26849-01
Top Assembly Revision Number : C0
Version ID : V03
CLEI Code Number : CNMWY00ARC
Hardware Board Revision Number : 0x09
Switch Ports Model SW Version SW Image
* 1 52 WS-C3560G-48TS 12.2(53)SE2 C3560-IPSERVICESK9-M
Configurations
2- on 4500 Side :
4500E#sh etherchannel su
4500E#sh etherchannel summary
d - default port
Number of channel-groups in use: 3
Number of aggregators: 3
45 Po45(SU) - Gi1/42(P) Gi1/43(P) Gi1/44(P)
Gi1/45(P) Gi1/46(P) Gi1/47(P)
Gi1/48(P)
4500E#sh int port-channel 45
Hardware is EtherChannel, address is 0007.7d64.0529 (bia 0007.7d64.0529)
Description: 4500---3560 Bundle
MTU 1500 bytes, BW 7000000 Kbit/sec, DLY 10 usec,
reliability 255/255, txload 197/255, rxload 124/255
Full-duplex, 1000Mb/s, media type is N/A
Members in this channel: Gi1/42 Gi1/43 Gi1/44 Gi1/45 Gi1/46 Gi1/47 Gi1/48
Last input 00:00:01, output never, output hang never
Last clearing of "show interface" counters 02:18:08
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 49122
5 minute input rate 3417084000 bits/sec, 522307 packets/sec
5 minute output rate 5415228000 bits/sec, 674449 packets/sec
4139848421 packets input, 3419495488468 bytes, 0 no buffer
Received 53945 broadcasts (25299 multicasts)
5286307877 packets output, 5330349202928 bytes, 0 underruns
0 unknown protocol drops
Last clearing of "show interface" counters 02:18:14
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
5 minute input rate 3414069000 bits/sec, 521786 packets/sec
5 minute output rate 5409966000 bits/sec, 673824 packets/sec
4142893680 packets input, 3421981735262 bytes, 0 no buffer
Received 53990 broadcasts (25320 multicasts)
5290299377 packets output, 5334375403783 bytes, 0 underruns
4500E#sh version
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500e-IPBASEK9-M), Version 15.2(2)E8, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Mon 22-Jan-18 06:32 by prod_rel_team
ROM: 12.2(44r)SG9
4500E uptime is 24 weeks, 10 hours, 22 minutes
System image file is "bootflash:cat4500e-ipbasek9-mz.152-2.E8.bin"
Hobgoblin Revision 20, Fortooine Revision 1.40
Last reload reason: power-on
export@cisco.com.
cisco WS-C4948E (MPC8548) processor (revision 5) with 1048576K bytes of memory.
Processor board ID CAT1524S1KJ
MPC8548 CPU at 1GHz, Cisco Catalyst 4948E
Last reset from PowerUp
4 Virtual Ethernet interfaces
48 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Configuration register is 0x2101
4500E#sh run int port-channel 45
Current configuration : 99 bytes
description 4500---3560 Bundle
switchport
end
4500E#
Hope to find some help .
Thanks in advance .
0 Replies 0
