Catalyst9000 autoconf and interface-template
HUBERT RESCH
Level 3
Level 3
Hi all,
I try to achive following:
I want to assign a interface-template to all my access-port (which fit nearly all my requirements. this works fine:
ACCESS-SWITCH-IBNS20#sh running-config interface gigabitEthernet 1/0/1
interface GigabitEthernet1/0/1
device-tracking attach-policy IPDT_ACCESS_PORT_MAX_10
access-session inherit disable interface-template-sticky
no macro auto processing
source template PORT-TEMPLATE_ACCESS_PORT_CLOSED_AUTH_DOT1X_MAB
spanning-tree portfast
end
ACCESS-SWITCH-IBNS20#sh derived-config interface gigabitEthernet 1/0/1
Building configuration...
Derived configuration : 947 bytes
description + ACCESS PORT CLOSED_AUTH_DOT1X_MAB
switchport access vlan 851
switchport mode access
switchport nonegotiate
switchport voice vlan 751
load-interval 30
authentication periodic
authentication timer reauthenticate server
access-session control-direction in
access-session closed
access-session port-control auto
mab
dot1x pae authenticator
dot1x timeout supp-timeout 7
dot1x max-req 3
storm-control broadcast level 0.50
storm-control multicast level 0.50
storm-control action trap
spanning-tree bpduguard enable
service-policy type control subscriber POLICY-MAP_CLOSED_AUTH_DOT1X_MAB
service-policy input POLICY-MAP_INPUT_TRUST_DSCP
service-policy output POLICY-MAP_OUTPUT-QUEUEING
ip dhcp snooping limit rate 25
end
I also want to use autoconf to assign a different interface-template if an AP is detected (Flex-Connect-AP), I tested it and also this works if nothin other is configuren on the interface, the correct interface-template is assigne dynamically.
ACCESS-SWITCH-IBNS20#sh run int gig 1/0/13
interface GigabitEthernet1/0/13
spanning-tree portfast trunk
end
ACCESS-SWITCH-IBNS20#sh cdp neigh gig 1/0/13
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone,
D - Remote, C - CVTA, M - Two-port Mac Relay
Device ID Local Intrfce Holdtme Capability Platform Port ID
AP5C5A.C7E3.5D04 Gig 1/0/13 128 R T AIR-AP280 Gig 0
Total cdp entries displayed : 1
ACCESS-SWITCH-IBNS20#sh device classifier attached interface gig 1/0/13
Summary:
MAC_Address Port_Id Profile Name Device Name
5c5a.c7e3.5d04 GigabitEthernet1/0/13 Cisco-AIR-LAP cisco AIR-AP2802I-E-K9
ACCESS-SWITCH-IBNS20#sh template binding target gigabitEthernet 1/0/13
Interface Templates
Interface: Gi1/0/13
Method Source Template-Name
dynamic User AP_FLEX_INTERFACE_TEMPLATE
Service Templates
Template-Name Source Bound-To-MAc
ACCESS-SWITCH-IBNS20#sh derived-config interface gigabitEthernet 1/0/13
Derived configuration : 666 bytes
description + ACCESS-POINT in FLEX-CONNECT-MODE
switchport trunk native vlan 870
switchport trunk allowed vlan 771,801,870,871
switchport mode trunk
load-interval 30
end
Now my question:
if I statically assign an interface-template and with autoconf a dynamic interface-template is assigned as well, according to some documentation if command are in both templates the command from the dynamic template is preferred.
All others is merged from both template.
Is there a way to avoid this merging, because for example in the static assigned template are following commands included:
mab
there is no way to configure in the dynamic template:
no access-session closed
no access-session port-control auto
no mab
because both templates are merged I will have these commands always in the derived config ?
Any Idea ?
Thx
Hubert
0 Replies 0
