802.1q trunk between 4451x and 2960
ajohnson
Hello! I cannot get my devices to communicate on anything outside of (native) vlan 1. Typically, I configure sub-interfaces, but I have found out that does not work. I am researching EVCs/Service-instances, but have not found a successful solution. My router config looks like:
interface GigabitEthernet0/0/2
 no ip address
 negotiation auto
 service instance 1 ethernet
  encapsulation dot1q 1
  rewrite ingress tag pop 1 symmetric
  bridge-domain 1
 service instance 2 ethernet
  encapsulation dot1q 2
  bridge-domain 2
 service instance 3 ethernet
  encapsulation dot1q 3
  bridge-domain 3
 service instance 4 ethernet
  encapsulation dot1q 4
  bridge-domain 4
**ommited config**
interface BDI1
 ip address 10.226.80.254 255.255.255.0
 ip policy route-map FILTER
interface BDI2
 ip address 10.226.84.254 255.255.254.0
interface BDI3
 ip address 10.226.88.254 255.255.254.0
interface BDI4
 ip address 10.226.92.254 255.255.254.0
Any thoughts as to what is wrong?
Thank you in advance.
sarathpa
May i know did you try with SVI model like below configuration. Also I could see that the "trunk" is not enabled on the interface.
Eg:
Switch (config)# interface gigabitethernet0/0/2
Switch (config)# switchport mode trunk
Switch (config)# switchport trunk allowed vlan none
Switch (config-if)# service instance 2 Ethernet
Switch (config-if-srv)# encapsulation dot1q 2
Switch (config-if-srv)# rewrite ingress tag pop 1 symmetric
Switch (config-if-srv)# bridge-domain 2
Switch (config)# interface vlan 2
Switch (config-if)# ip address 10.226.80.254 255.255.255.0
