802.1Q trunk over a L2TPV3 Tunnel
alig.norbert
Level 4
Level 4
Hi all,
I'm just curios about this scenario.
Can a switch-to-switch 801.1Q trunk be expand over an L2TPV3 connection or does it need a 802.1Q-in-Q before it goes through the tunnel?
Thanks folks,
Norbert
bmahaffey
Cisco says you can.
How I have it configured is a vlan per sub interface.
Ethernet over L2TPv3
http://www.cisco.com/en/US/netsol/ns588/netqa09186a008009d4ea.html
Q. What are the main applications of Ethernet over L2TPv3?
A.
* Ethernet Trunking: enables user to take all of the Ethernet on an associated interface and tunnel it across an IP core to a remote destination.
* Per-VLAN Tunneling: enables the tunneling of individual VLANs. This method offers the granularity of controlling which of the traffic is tunneled to a given destination.
* VLAN Trunking: similar to Ethernet trunking, all VLANs that are associated with an 802.1q-based interface are passed across the L2TPv3 Tunnel. This is useful in trunking applications between Ethernet Switches.
I know you seen this but if someone else sees this, here is the configuration guide.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios120/120newft/120limit/120s/120s23/l2tpv3.htm
the links with configuration is no longer exist and other source
