802.1x Authentication Configuration
albayrak8791
I have one 3560 L3 Switch and trying to configure 802.1x. All configuration seems fine but I think I'm missing something on the server side or Client.
Which configurations do i need to do on server side ? thanks for your help
6 Replies 6
Client side: windows XP / 2k (SP4)EAPOL client
Radius side: we?ve worked with MS IAS imported users profiles from MS Active directory also EAP and EAPTLS and it?s running fine.
Luis
Can you provide bit more details about server configuration ? All i need is to know about the IAS part...
Next monday Iwill try to send you more info about Radius Server config.
Good week end
Luis
The server config bassed in ACS is related in this 2 anexed documents.
Thank you...
davidfc_A
The microsoft document named "Securing Wireless LANS With PEAP and Passords" have a good explanation about IAS, architecture, placement, configs...
It is not the same authentication mode that you are asking, but it will help.
Best Regards!
