802.1x clarification...
jimmysands73_2
Level 5
Level 5
For ports would this be correctly paraphrased?
Force-unauthorized - Port is effectively shutdown to all traffic.  Switch can not provide authentication to the client, effectively disabling this port.
Force-authorized - No authentication necessary, port would work when cable connected (granted other port config is correct).
Auto - Enables 802.1x, allows EAPOL frames to be sent/recv'd on this port.  If authentication succeeds, changes to authorized state and traffic passes.  If authentication fails, attempt to re-authenticate can be tried.
Julio Carvajal
Hello Jimmy,
1- Force-unauthorized: Port cannot be used as it's unathorized. It will ignore all traffic ( even 802.1x traffic)
2-Force-authorized: 802.1x is not enabled on the interface, all traffic is allowed on the interface, Its the default state.
3-Auto: 802.1x is enabled on the interface, It will allow ( EAPOL,CDP and STP traffic ) before it authenticates succesfully, afterwards all traffic will be allowed.
Please rate all the helpful posts
Julio
Cisco Engineer
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Julio Carvajal
Hello Jimmy,
Julio
Cisco Engineer
Julio Carvajal
Hi Guys,
Could someone please provide scenarios for the different use cases; it is obvious when to use the auto option. But when would you use Force-unauthorized or Force-authorized?
Allen
Hello Allen:
Force-Unauthorized: Over a port that is not being used.
Force-Authorized: Over a port where the client does not support 802.1x and you want to grant permission to him.
Any other question..Sure.. Just remember to rate all of my answers.
Julio
Julio Carvajal
