802.1x in Juniper EX series to cisco 9200
Jsapkom
can anyone help to change the below Juniper 802.1x config to Cisco 9200 config.
set protocols dot1x authenticator authentication-profile-name CLIENT-AUTH
set protocols dot1x authenticator interface OFFICE-LAN supplicant single-secure
set protocols dot1x authenticator interface OFFICE-LAN retries 3
set protocols dot1x authenticator interface OFFICE-LAN transmit-period 20
set protocols dot1x authenticator interface OFFICE-LAN reauthentication 3153600
set protocols dot1x authenticator interface OFFICE-LAN supplicant-timeout 20
set protocols dot1x authenticator interface OFFICE-LAN server-timeout 30
set protocols dot1x authenticator interface OFFICE-LAN server-fail deny
set access radius-server xxx.xxx.xxx.xxx secret "dfgserhdfhhdfhdhdfgdgdfgd"
set access radius-server yyy.yyy.yyy.yyy secret "552525252525fdgssdg34sers"
set access profile CLIENT-AUTH authentication-order radius
set access profile CLIENT-AUTH radius authentication-server xxx.xxx.xxx.xxx
set access profile CLIENT-AUTH radius authentication-server yyy.yyy.yyy.yyy
Thank you
7 Replies 7
Jsapkom
The OFFICE-LAN comprises interface range and has been configured with a vlan 100.
I have already mapped the configuration according to the document but how do we assign the vlan 100 once authentication is successful.
Do we need to make any change on the ISE/ Authentation server or at client end as well when we are replacing the Juniper with Cisco switch
You should not need to make any changes on the client end, as you are simply replacing one vendor with another one. As for Cisco ISE, I am not familiar with it but if it worked in the past with Juniper switches, it should work fine with Cisco.
for the client not need for ISE I think you need to use cisco dictionary  instead of Juniper dictionary
MHM
