07-26-2015 08:36 AM - edited 03-08-2019 01:07 AM
Good morning , please could you support to us in the following question?
2960 24 TC-L one of its feature is 2 dual purpose uplink ports , it means one RJ-45 and one SFP port , by default when we start the switch the SFP port goes to active keeping the RJ-45 port down , they are not redundant ports , the question is : when the SFP link goes down for any problem the RJ-45 should change to active and according to the information it should be done automatically , how long time does take since the time that SFP link goes down till the RJ-45 start to transmit the information .
Thanks for your Support
Ricardo
07-26-2015 10:04 AM
The ports must have the same speed and duplex. You also need to put the ports in a Portchannle.
Can you post the config?
07-28-2015 11:59 AM
Hi Reza , SW 2960 24 TC-L , we would use dual purpose ports one of them is RJ45 and another SFP, the ethernetchannel is for getting a fault tolerance if any port fail :
the next configuration is for one of the SW another switch would have the same configuration:
SW0(config)#int range gigabitethernet 0/25 - 26
SW0(config-if-range)#shut ctrlz
SW0(config)#int gigabitethernet 0/25
SW0(config)#media type rj45 ctrlz
SW0(config)#int gigabitethernet 26
SW0(config)#media type sfp ctrlz
SW0(config-if-range)# speed 100
SW0(config-if-range)# duplex full
SW0(config-if-range)# channel-group-1 mode on , ctrlz
to verify the configuration
SW0#sh run , to see the configuration also
SW0#sh ip int breaf , to see the port channel
SW0#sh spanning-tree
SW0#sh etherchannel detail , to see the port channel detail
the VLAN would be the same by default configuration , it is VLAN1 we do not need another VLAN
if you have any suggestions we appreciate it
02-29-2024 11:42 AM
Bonjour, svp j'ai le même modèle du switch, il m'affiche des caractères bizarres lors de l'accès via la console, c'est quoi le problème svp. Aussi je n'arrive pas à le réinitialiser pour une nouvelle configuration, comment procéder pour le réinitialiser ? Et merci par avance.
