802.1x Multi-Host Mode
s.painemal
I know that in this mode, when the first host authentication fail, the remaining host are limited too. But is it posible that each host can be autheticated
separately without being affected for the firs host, when it fails.
mattkaya56
The mode you are looking for is multi-auth. Not all switches support - the higher end switches do. I remember it was supported on 3750
build 12.2(50) S.E and later.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_50_se/command/reference/cli1.html
