802.1x on 2960 cluster switch
chitre_salil
I am trying to get 802.1x port based authentication working on a cluster switch member. All the switches are 2960 series veriosn 12.2 (44) SE2. Only the cluster commander has an IP set and that is configured on the radius server (Windows 2008 NPS) as a client.
I have the following configuration on all the cluster switches
aaa new-model
aaa authentication dot1x default group radiusx
radius-server host 172.19.x.xx auth-port 1645 acct-port 1646
radius-server key xxxxx
The switch port that I am testing has the following config
interface fa0/15
switchport mode access
dot1x port-control auto
no shut
I cant see anything in the logs on the cluster member. The radius server has no requests in its log either. Anyone has any clues?
Regadrs,
Salil
Ganesh Hariharan
Hi ,
Try configuring 802.1x as per the link
http://www.cisco.com/en/US/products/hw/switches/ps708/products_configuration_example09186a00808066ba.shtml#switch
hope this will you to over come the issue
Ganesh.H
Hi Ganesh,
Thanks for the link. The configuration I am using works perfect if I use it on a standalone switch. It proves that my Switch config, radius server config and client config is working. Its only when I try to use the same switch config on a switch cluster that I cant get it to work. I have tried giving the cluster member its own IP address so that it can communicate with the radius server directly but it did not help.
On the client I can see the EAPOL start message generated. I dont see the switch querying the client for authentication details. The switch simply enables the port. The switch port config is
interface FastEthernet0/15
switchport access vlan xxx
dot1x pae authenticator
dot1x violation-mode protect
spanning-tree bpduguard enable
I am not sure if there is anything else required to get this working in a switch cluster.
Salil
Try to configure cluster ip and static ip of the switch in acs aaa client tab then see what happens.
Ganesh.H
