802.1X with Supplicant
mciarlo
When initiate the first login dont validate the user to the DOMAIN in WinXP.
Why appears this Problems?
Hi Mciarlo,
Wich Catalyst model and Ios are you using?. WCan you send me the configuration are you using?
Luis
Hi Luis,
the catalyst its a 3750. I send you the config,
int r f1/0/1 - 24
switchport mode access
speed 100
duplex full
dot1x pae authenticator
dot1x port-control auto
dot1x host-mode multi-host
spanning-tree portfast
spanning-tree bpduguard enable
spanning-tree guard root
TKS
Martin
