802.1x
alsayed
Level 7
Level 7
Dear Netpro!
this command enough to come up the 802.1x:
aaa new-model
aaa authentication dot1x default group radius
or
do i need the seconde Line:
aaa authentication login LOCAL line enable local none
then:
//line con 0
login authentication LOCAL
//line vty 0 15
or No Need it!
many 10xs
royalblues
Level 11
Level 11
Ali,
Dot1x is a port authentication that restricts unauthorised clients from connecting to the line.
In additional to above commands you will need the follwoing under the interface that needs to use dot1x
interface
dot1x port-control auto
More info here
http://www.cisco.com/en/US/docs/switches/lan/catalyst2950/software/release/12.1_9_ea1/configuration/guide/Sw8021x.html
The commands under the consoel and VTY lines would enable aaa on these for the group. If default group is used it applies to all the lines
Narayan
I Knew the all the Config:but the Question is:
does it comes up without this Comand:
The commands listed by you are the fallback methods for login and i dont think would be nneded for dot1x
Narayan
