Showing results forĀ
Search instead forĀ
Did you mean:Ā
827 router problem
wael azzam
Hi all,
I have  cisco router 827 and it is working that have interface ethernet0 which workes on 10M/half duplex and the problem i configure it to 100M/Full duplex.
Note that the system software is (C820-K9OSY6-M), Version 12.3(26)
5 Replies 5
wael azzam
Hi all,
I have  cisco  router 827 which has one interface  ethernet0 workes  on 10M/half duplex and the problem i cant configure it to 100M/Full duplex.
it depends on what is on the oposite side of your router and then decide if you can configure your interface to 100M/full duplex.
If you configure ethernet0 to duplex auto and speed auto so what is result?
Jan
thanks Jan ,
there is no speed or duplex commands under (interface ethernet 0) ,is it posssible
regarding of the software version it would be possible. But regarding of hardware i think it is not. So if you want to use greater speed you will have to replace your current router with newer model.
Jan
Thanks Jan for your help
