871 Problem - Cannot Ping Any Outside IP Addresses
stu.packett
I have an 871 that I would like the FE4 WAN port to get an IP address from the WAN DHCP server and the inside IP address to be 10.17.1.x/24. The goal is for remote users to bring the 871 with them and plug in an IP phone. Right now, when I plug the 871 in, I do get an outside IP address on the WAN port, but I cannot ping any outside IP addresses. Could you please see my config and tell me what I'm doing wrong? I think it may be a NAT problem. Thank in advance.
or871#sh run
Building configuration...
Current configuration : 3059 bytes
version 12.3
no service pad
hostname or871
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret xxxx
username cisco privilege 15 secret xxxx
no aaa new-model
ip subnet-zero
ip cef
ip dhcp excluded-address 10.17.1.1
ip dhcp pool or871-pool
import all
network 10.17.1.0 255.255.255.0
dns-server 10.54.0.6 10.54.0.7
domain-name or.local
option 150 ip 10.54.0.10
default-router 10.17.1.100
no ip domain lookup
ip domain name or.local
no ftp-server write-enable
interface FastEthernet0
no ip address
no cdp enable
interface FastEthernet1
no ip address
no cdp enable
interface FastEthernet2
no ip address
no cdp enable
interface FastEthernet3
no ip address
no cdp enable
interface FastEthernet4
description WAN Interface
ip address dhcp
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
no cdp enable
interface Dot11Radio0
no ip address
shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
no cdp enable
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
ip address 10.17.1.100 255.255.255.0
ip nat inside
ip tcp adjust-mss 1452
ip classless
ip route 0.0.0.0 0.0.0.0 FastEthernet4
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 600 life 86400 requests 10000
ip nat inside source list 1 interface FastEthernet4 overload
access-list 1 permit 10.17.1.0 0.0.0.255
no cdp run
control-plane
line con 0
logging synchronous
login local
no modem enable
transport preferred all
transport output all
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
end
or871#
9 Replies 9
your configuration looks ok, I think the problem might be your default route, whcih points to FastEthernet4, can you replace that with a default route to the next hop address:
ip route 0.0.0.0 0.0.0.0 X.X.X.X
where X.X.X.X is the IP address of the next hop, and not FastEthernet4...
HTH,
GP
Is there a way to avoid using the IP address of the next hop? Thanks, that did work, but the goal is to have my remote users bring this router from client site to client site without them or me having to configure the router. We're so used to have a PIX 501, but we would like to take advantage of the QoS and wireless on the 871.
the problem is that when you define an Ethernet interface as next hop, the router sends an Address Resolution Protocol (ARP) request for your destination address, which the router realizes is not on this interface. The ARP entry for this address is "Incomplete," as seen by the show arp command. An encapsulation failure then occurs as the router is unable to put the packet on the wire with no ARP entry.
So, you need the next hop IP address for this to work...
HTH,
GP
I agree with Georg that from a reliability standpoint the static route with next hop address is the best solution. A static route which specifies the Ethernet interface instead of a next hop address will work IF the next hop layer 3 device supports proxy ARP. But not all routers are set to support proxy ARP. So the static route with interface specified may work or may not and the static route with next hop address will always work (if you have the correct next hop address configured). So the original poster will have to decide which is better: a more flexible solution which requires no config change as they move from site to site and may or may not work or a solution which always works but requires config changes when they move from site to site.
As a side note: the implementation of static route specifying a LAN interface will make the router work harder than a static route with next hop. The router will be sending lots more ARP requests, will have a much bigger ARP table to manitain, and will spend some extra CPU cycles maintaining the larger ARP cache. This is not true of static routes with a point to point interface but is true for static routes with a LAN interface.
Rick
Rick
I am curious why are you putting in a default route for the WAN. If you are doing DHCP client on that interface it should receive a default route from the DHCP server automatically. This would resolve all your problems.
How did you use the PIX do you have a sample config for it?
Just curious.
Rate if it helps!
Mike
I agree. With DHCP, the router will create a static route for you automatically with a distance of 254. You can verify this with "show ip route". Mine looks something like this:
Cisco871W#show ip route
Gateway of last resort is 1.2.3.4 to network 0.0.0.0
C 192.168.1.0/24 is directly connected, VLan1
C 1.2.3.0/24 is directory connected, FastEthernet4
S* 0.0.0.0/0 [254/0] via 1.2.3.1
desai.jaideep
Level 5
Level 5
Though its not advisiable,but try giving both the routes.
The one with FastEthernet and one with IP address.
Since both the routes are routed through same interface, there wont be any effect.
Pls try it
JD
BillBores
You need to remove IP CEF. This will fix your problem. I have had this problem before and just yesterday afternoon could not get an IP address via DHCP. I removed the IP CEF statement and ...BAM... got an IP address on FE4.
Bill Bores
lowes.jgibson
I dont know ... I use a route map for my 1811...try this:
ip nat inside source route-map NAT-RM interface FastEthernet4 overload
access-list 101 permit ip 10.17.1.0 0.0.0.255 any
route-map NAT-RM permit 1
match ip address 101
