Load Balancing
imranraheel
Level 5
Level 5
I have a 871 with a single Internet connection DSL with Public static IP on both modem(DSL)and Router 2 VPN's are also working .What I want to do is to seperate the load I mean to say if one ISP goes down the other should work as I have another Internet connection for backup is there any possibility plz reply me
thestagman
Level 3
Level 3
you could try a floating static route ie a static route pointing to the back up internet connection with a higher cost
johnnylingo
Level 9
Level 9
Do you have static IP(s) or DHCP?
Also you're running NAT I assume?
