871W - Wireless Devices Cannot Communicate with Each Other
chrislisser
I am supporting a home setup of an 871W router. The user is reporting that he is able to access the Internet using the wireless from his PC, he can ping his wireless printer from the router, but the PC and printer cannot connect to each other.
Here is the config from the 871W... am i missing something?
chrislisser
!version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 51200 debugging
logging console critical
no aaa new-model
resource policy
clock timezone PCTime 0
no ip source-route
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.0.0.1
ip dhcp pool sdm-pool1
import all
network 10.0.0.0 255.255.255.0
default-router 10.0.0.1
ip tcp synwait-time 10
no ip bootp server
ip ssh time-out 60
ip ssh authentication-retries 2
crypto pki trustpoint TP-self-signed-1812774468
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1812774468
revocation-check none
rsakeypair TP-self-signed-1812774468
crypto pki certificate chain TP-self-signed-1812774468
certificate self-signed 01
30820247 308201B0 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
F60984C4 E46F56D7 C5313D
quit
bridge irb
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
description $ES_WAN$$FW_OUTSIDE$
ip address dhcp client-id FastEthernet4
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip virtual-reassembly
ip route-cache flow
duplex auto
speed auto
interface Dot11Radio0
no ip address
encryption key 1 size 128bit 7 xxx transmit-key
encryption mode wep mandatory
ssid xxx
authentication open
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
bridge-group 1
bridge-group 1 spanning-disabled
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$FW_INSIDE$
no ip address
ip tcp adjust-mss 1452
bridge-group 1
interface BVI1
description $ES_LAN$
ip address 10.0.0.1 255.255.255.0
ip nat inside
ip tcp adjust-mss 1412
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface FastEthernet4 overload
logging trap debugging
access-list 1 remark INSIDE_IF=BVI1
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.0.0.0 0.0.0.255
no cdp run
control-plane
bridge 1 protocol ieee
bridge 1 route ip
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
login local
no modem enable
transport output telnet
line aux 0
login local
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
webvpn context Default_context
ssl authenticate verify all
no inservice
end
This sounds more related to perhaps a driver issue for the printer.
I understand that both printer and PC are on the same subnet by reading this show run, can you confirm that is the case?
The average network printer is responding to a brodcast request with its hostname and ip, that is how the PC detects it. Hence it's important by default to have both on the same subnet, else it becomes more tricky to configure.
Finally, what happens when the PC is wired connected? I presume, the same issue will happen.
They are on the same subnet. I'm not sure about the rest. I will check with the user and have them test with the wired port tonight. I also asked that he update his PC wireless drivers. He said it did work wirelessly with his previous WLAN setup (without the 871W)
He is also reporting that he cannot ping the PC from the router, but he says there is no firewall running on the PC.
If he can ping the router from the PC but not the PC from the router, then it's obviously a firewall issue on the pc.
