877 not applying NTP time
clark-computers
I have an 877 that I have configured to retreive its clock from the internal DC. It appears to get the NTP packet but is then somehow unable to apply the data. Here is the debug:
187581: *Oct 30 13:48:39.286: NTP: xmit packet to 10.0.0.10:
187582: *Oct 30 13:48:39.286: leap 3, mode 3, version 3, stratum 0, ppoll 1024
187583: *Oct 30 13:48:39.286: rtdel 0000 (0.000), rtdsp 10001 (1000.015), refid 00000000 (0.0.0.0)
187584: *Oct 30 13:48:39.286: ref 00000000.00000000 (00:00:00.000 GMT Mon Jan 1 1900)
187585: *Oct 30 13:48:39.286: org CE956957.B888D526 (13:32:07.720 GMT Fri Oct 30 2009)
187586: *Oct 30 13:48:39.286: rec CE956937.4A322BBC (13:31:35.289 GMT Fri Oct 30 2009)
187587: *Oct 30 13:48:39.286: xmt CE956D37.4976A298 (13:48:39.286 GMT Fri Oct 30 2009)
187588: *Oct 30 13:48:39.286: NTP: rcv packet from 10.0.0.10 to 10.0.0.2 on BVI1:
187589: *Oct 30 13:48:39.286: leap 0, mode 4, version 3, stratum 2, ppoll 1024
187590: *Oct 30 13:48:39.286: rtdel 0FFF (62.485), rtdsp AF234 (10946.106), refid 0A910A01 (10.145.10.1)
187591: *Oct 30 13:48:39.286: ref CE956CD1.567929B7 (13:46:57.337 GMT Fri Oct 30 2009)
187592: *Oct 30 13:48:39.286: org CE956D37.4976A298 (13:48:39.286 GMT Fri Oct 30 2009)
187593: *Oct 30 13:48:39.286: rec CE956D57.6E898C05 (13:49:11.431 GMT Fri Oct 30 2009)
187594: *Oct 30 13:48:39.290: xmt CE956D57.6E898C05 (13:49:11.431 GMT Fri Oct 30 2009)
187595: *Oct 30 13:48:39.290: inp CE956D37.4A2D2713 (13:48:39.289 GMT Fri Oct 30 2009)
187596: *Oct 30 13:48:39.290: NTP: 10.0.0.10: offset 32.143427323, delay 0.00278, error 0.00002clock_filter(10.0.0.10, 32.143427, 0.00278, 0.00002)
187597: *Oct 30 13:48:39.290: NTP: nlist 0, allow 0, found 0, low 0.000000, high 0.000000
187598: *Oct 30 13:48:39.290: NTP: no select intersection
187599: *Oct 30 13:48:39.290: NTP: no select intersection
The config is simply 'ntp server 10.0.0.10'. Any ideas what's up here?
Giuseppe Larosa
Hello Andrew,
debug shows NTP packets are received and sent.
try to add the following:
access-list 25 permit host 10.0.0.10
ntp peer access-group 25
ntp source BVI1
Hope to help
Giuseppe
Leo Laohoo
How to configure an authoritative time server in Windows Server
http://support.microsoft.com/kb/816042
lgijssel
Level 9
Level 9
Please refer to the following to verify your ntp configuration:
http://www.cisco.com/en/US/docs/switches/lan/catalyst4000/8.2glx/configuration/guide/ntp.html
regards,
Leo
