877w router WIFI routed configuration not bridged
Criterion
Hi everyone,
I'm trying to setup cisco 877w router and wifi in routed configuration as opposed to bridged. Also aiming to have a guest vlan that is separated from the main network as the guest ssid.
Problem I'm having at the moment is routing (or any communication) between my main wifi subnet (which is configured as 'test' at the moment) and my wired subnet, both on vlan 1. I must be missing something really simple but I'm learning so please explain or refer to documentation that explains what I had missed and the solution to it.
Below is my config (thanks in advance):
version 15.1
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname <name>
boot-start-marker
boot-end-marker
logging buffered 51200
logging console critical
aaa new-model
aaa authentication login default local
aaa authentication login sdm_vpn_xauth_ml_1 local
aaa authorization exec default local
aaa authorization network sdm_vpn_group_ml_1 local
aaa session-id common
clock timezone Bri 10 0
crypto pki trustpoint TP-self-signed-2977923712
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-2977923712
 revocation-check none
 rsakeypair TP-self-signed-2977923712
dot11 mbssid
dot11 association mac-list 700
dot11 syslog
dot11 ssid test
 vlan 1
 authentication open
 authentication key-management wpa
 guest-mode
 wpa-psk ascii 7 <key>
no ip source-route
no ip dhcp use vrf connected
ip dhcp pool sdm-pool1
 import all
 network 172.16.0.0 255.255.255.0
 default-router 172.16.0.1
 dns-server 203.12.160.35 203.12.160.36 4.2.2.2
ip dhcp pool testwifi
 import all
 network 172.16.1.0 255.255.255.0
ip cef
no ip bootp server
no ip domain lookup
ip name-server 203.12.160.35
ip name-server 203.12.160.36
ip name-server 4.2.2.2
no ipv6 cef
archive
 log config
  hidekeys
username <admin/root user>
ip ssh version 2
interface ATM0
 no ip address
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip mtu 1492
 ip virtual-reassembly in
 no atm ilmi-keepalive
interface ATM0.1 point-to-point
 description $FW_OUTSIDE$$ES_WAN$
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 pvc 8/35
  tx-ring-limit 3
  pppoe-client dial-pool-number 1
interface FastEthernet0
 no ip address
interface FastEthernet1
 no ip address
interface FastEthernet2
 no ip address
interface FastEthernet3
 no ip address
interface Dot11Radio0
 no ip address
 ip virtual-reassembly out
 ip tcp adjust-mss 1400
 encryption vlan 1 mode ciphers aes-ccm tkip
 ssid test
 speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
 station-role root
interface Dot11Radio0.1
 encapsulation dot1Q 1 native
 ip address 172.16.1.1 255.255.255.0
 ip nat inside
 no cdp enable
interface Vlan1
 description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$$FW_INSIDE$
 ip address 172.16.0.1 255.255.255.0
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip nat inside
 ip tcp adjust-mss 1460
interface Dialer0
 ip address negotiated
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip mtu 1492
 ip nat outside
 encapsulation ppp
 dialer pool 1
 dialer-group 1
 ppp authentication pap callin
 ppp pap sent-username <dsl creds>
 no cdp enable
router rip
 network 172.16.0.0
ip forward-protocol nd
ip http server
ip http secure-server
ip nat inside source list NAT_PERMIT_RANGE interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
ip access-list extended ACL_PERMIT_INTERNAL
 permit ip 172.16.0.0 0.0.0.255 172.16.1.0 0.0.0.255
 permit ip 172.16.1.0 0.0.0.255 172.16.0.0 0.0.0.255
ip access-list extended NAT_PERMIT_RANGE
 permit ip 172.16.0.0 0.0.0.255 any
 permit ip 172.16.1.0 0.0.0.255 any
access-list 700 permit 0000.0000.0000   ffff.ffff.ffff
dialer-list 1 protocol ip permit
no cdp run
control-plane
line con 0
 logging synchronous
 no modem enable
line aux 0
line vty 0 4
 logging synchronous
 transport input telnet ssh
 transport output all
scheduler max-task-time 5000
ntp server 130.102.128.23
ntp server 203.14.0.250
end
10 Replies 10
Philip D'Ath
The default router is wrong in the dhcp pool.
 import all
It should be:
 import all
 default-router 172.16.1.1
Hey Phillip, Thanks for the response. Just because it's a different interface of the SAME router, I didn't see the effect it could have and had it configured like that originally to test to see if it will work. Worked fine for the internet and nat. I realise that technically it should be how you pointed it out to be.
I just changed it, but to no avail. I can ping the VLAN1 interface on 172.16.0.1 but not anything else in that subnet. Does that sound right?
C:\Users\surface>ping 172.16.0.1
Pinging 172.16.0.1 with 32 bytes of data:
Reply from 172.16.0.1: bytes=32 time=2ms TTL=255
Reply from 172.16.0.1: bytes=32 time=197ms TTL=255
Reply from 172.16.0.1: bytes=32 time=135ms TTL=255
Reply from 172.16.0.1: bytes=32 time=184ms TTL=255
Ping statistics for 172.16.0.1:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 2ms, Maximum = 197ms, Average = 129ms
C:\Users\surface>ping 172.16.0.22
Pinging 172.16.0.22 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 172.16.0.22:
    Packets: Sent = 4, Received = 0, Lost = 4 (100% loss)
On the wireless, if you are not bridging why not have the following:
dot11 ssid test
 authentication open
 guest-mode
interface
Dot11Radio0
ip address
 ip nat inside
ip
 encryption mode ciphers aes-ccm tkip
 ssid test
 station-role root
**Please rate posts you find helpful**
Hi, thanks for the response John. You must have missed the part where I stated that I was going to have more than one vlan for the purposes of a segregated guest network that would be isolated from the main network. Hence the reason why I have mbssid and sub-interfaces for DotRadio configured :)
Okay, you will need to bridge and have different vlans. Have a look at the following doc:
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/116579-configure-technology-00.html
John
I think I have a bigger problem. I tried to ping a device on the Vlan1 subnet; i.e.172.16.0.0 subnet, specifically 172.16.0.3; a device which can ping and receive a response from the router but the router cannot ping it:
RTR01#ping 172.16.0.3
Sending 5, 100-byte ICMP Echos to 172.16.0.3, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Vlan1 interface on the router responds:
RTR01#ping 172.16.0.1
Sending 5, 100-byte ICMP Echos to 172.16.0.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms
Things I've tried so, thinking it might to do with a routing problem, or ACL or whatever is as follow (added or modified to):
added:
router rip
network 172.16.1.0
ip route 172.16.0.0 255.255.255.0 vlan1
ip route 172.16.1.0 255.255.255.0 Dot11Radio 0.1
no dot11 association mac-list 700
Modified to:
You do not need static routes for directly connected interfaces.  Delete:
If the host can ping the router but the router can not ping the host then it is more likely to be an issue with a local host firewall, such as Windows Firewall.
Lastly, now that I got it working, Philip, I tested it out just for learning sake; Having both default router settings as 172.16.0.1 does not prevent pings from being routed. Technically speaking though, for consistency's sake, I've set it back to 172.16.1.1. Only logical to have it like that....
Criterion
Would you believe it? I had windows FW on which was blocking ICMP request and I finally got ping and other communications on vlan1 working now. Don't know if the any of the changes I made helped, but that was the final change I made before it worked.
