877w wireless not working
anishkgthomas
I've tried all possible way to get the wireless working,what could be wroing here is my config
Building configuration...
Current configuration : 4644 bytes
version 12.4
no service pad
hostname R877W
boot-start-marker
boot-end-marker
no logging console
enable secret 5 $1$GCxJ$575V8W80LBFEx4vVgH0t7/
no aaa new-model
dot11 syslog
dot11 vlan-name WiFi vlan 10
dot11 ssid Cisco
   vlan 10
   authentication open
   authentication key-management wpa
   mbssid guest-mode
   wpa-psk ascii 0 blackhawk365
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.1
ip dhcp excluded-address 192.168.1.254
ip dhcp pool Home
   network 192.168.1.0 255.255.255.0
   default-router 192.168.1.1
   dns-server 212.77.192.59 212.77.192.60
ip dhcp pool WiFi
   network 192.168.10.0 255.255.255.0
   default-router 192.168.10.1
ip name-server 212.77.192.59
ip name-server 212.77.192.60
username admin privilege 15 password 0 cisco
archive
log config
  hidekeys
bridge irb
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
pvc 8/35
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
no ip address
encryption vlan 10 mode ciphers aes-ccm tkip
broadcast-key vlan 10 change 30
ssid Cisco
mbssid
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Dot11Radio0.10
description vlan10
encapsulation dot1Q 10
ip nat inside
ip virtual-reassembly
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
ip nat inside
interface Vlan10
description WiFi
no ip address
ip nat inside
bridge-group 1
interface Dialer1
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
no cdp enable
ppp authentication pap chap callin
ppp chap hostname *********
ppp chap password 0 *********
ppp pap sent-username ********* password 0 *******
interface BVI1
ip address 192.168.10.1 255.255.255.0
ip nat inside
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer1
ip http server
ip http authentication local
no ip http secure-server
ip nat inside source list 10 interface Dialer1 overload
access-list 10 permit any
control-plane
bridge 10 protocol ieee
bridge 10 route ip
banner motd ^C
******************HOME ADSL ROUTER ************
********UNAUTHORISED ACCESS PROHIBITED*************
^C
line con 0
login local
no modem enable
line aux 0
password cisco
line vty 0 4
password cisco
login
scheduler max-task-time 5000
end
moshebendahan
hi try this conf
no service pad
service timestamps debug datetime localtime
service timestamps log datetime localtime
service password-encryption
no aaa new-model
no ip http server
ip cef
ip name-server X.X.X.X - ISP DNS
username XXXX
enable secret XXXX
hostname test2
ip dhcp pool LAN
dns-server X.X.X.X X.X.X.X
ip dhcp pool WLAN
network 10.10.10.0 255.255.255.0
default-router 10.10.10.1
ip address 10.10.10.1 255.255.255.0
ip nat inside
channel 8
power local cck maximum
power local ofdm maximum
encryption mode ciphers tkip
no shut
ssid My_Wireless
  guest-mode
  authentication open
  wpa-psk ascii 0 12345678
interface Vlan1
description "Connection to LAN"
ip nat inside
load-interval 30
hold-queue 100 out
interface Dialer 0
ip nat outside
encapsulation ppp
dialer pool 1
ppp pap sent-username test@ISP password 123456
interface ATM0
no ip address
pvc X/X
pppoe-client dial-pool-number 1
no shut
ip route 0.0.0.0 0.0.0.0 dialer0
access-list 2 permit 10.10.10.0 0.0.0.255
ip nat inside source list 2 interface Dialer0 overload
access-list 1 permit 192.168.1.0 0.0.0.255
ip nat inside source list 1 interface Dialer0 overload
line con 0
logging synchronous
login local
line vty 0 4
logging synchronous
login local
OR
no service pad
no aaa new-model
no ip http server
ip cef
ip name-server XXXX
ip name-server XXXX
username XXXX password XXXX
enable secret XXXX
hostname test1
ip dhcp pool LAN
dns-server XXXX XXXXX
no ip address
bridge-group 1
channel 8
no shut
ssid My_Wireless
  guest-mode
  authentication open
bridge irb
bridge 1 protocol ieee
bridge 1 route ip
interface Vlan1
description "Bridge with Wireless"
no ip address
bridge-group 1
interface BVI1
ip nat inside
load-interval 30
hold-queue 100 out
interface Dialer 0
ip nat outside
encapsulation ppp
dialer pool 1
interface ATM0
no ip address
pvc X/X
no shut
line con 0
logging synchronous
login local
line vty 0 4
logging synchronous
login local
13 Replies 13
Hi George,
I have no experience with the 877 in that way but maybe you have to delete the nat config from the "interface Dot11Radio0.10" , interface Vlan10 and interface BVI1. Thats what I see and looks strange for me.
If I would configure it I would use/create brige-groupe 10 and configure the IP to that interface to keep it simple for the view and is maybe necessary for the DHCP if that is not working too.
regards,
Sebastian
lal.antony
Hi George,
I think I see the issue. You have configured Bridge Group 1 in all of the bridging interfaces and then have Bridge Group 10 when you configure the protocol and route ip statements.
Change the Bridge Group ID from 10 to 1 in the following statements then you should be fine.
bridge 1 route ip
Hope this helps.
Cheers,
Lal Antony
www.lalantony.com
Thanks guys !
did not understand what sebastian had written. i've tried what lal suggested but no change.
The Green 'OK' light on the router is lit but the client does not get an ip address.
I've erased the ram and reloaded it. here is the config as of now,
Current configuration : 2935 bytes
version 12.4
no service pad
hostname R877W
boot-start-marker
boot-end-marker
no logging console
no aaa new-model
dot11 syslog
dot11 ssid Cisco
   vlan 10
   authentication open
   mbssid guest-mode
   wpa-psk ascii 7 045907070C2A444F1E12564147
ip cef
ip dhcp pool Home
ip dhcp pool WiFi
username admin privilege 15 password 7 104D000A0618
archive
log config
  hidekeys
bridge irb
interface ATM0
no ip address
pvc 8/35
no ip address
ssid Cisco
mbssid
station-role root
description Vlan10
encapsulation dot1Q 10 native
ip nat inside
bridge-group 1
interface Vlan1
ip nat inside
interface Vlan10
description WiFi
no ip address
interface Dialer1
ip nat outside
encapsulation ppp
dialer pool 1
no cdp enable
ppp chap hostname s4860348
ppp chap password 7 071E20584F1B4857
ppp pap sent-username s4860348 password 7 06170E354D5C584B
interface BVI1
ip nat inside
ip http server
control-plane
banner motd ^CC
^C
line con 0
login local
no modem enable
line aux 0
password 7 13061E010803
line vty 0 4
login
end
any help ?
Sorry Geroge if i make it not enough clear. If I have to configure the Router I would do it a little bit different and I would delete the NAT settings I see in your config in 0.10 and BVI.
What I think, the problem for DHCP is in the BVI configuration.
Remove the IP from BVI 1 and add this one to interface Vlan10.
Or you do it like I think at all:
description Vlan10
bridge-group 10
bridge-group 10 subscriber-loop-control
bridge-group 10 spanning-disabled
bridge-group 10 block-unknown-source
no bridge-group 10 source-learning
no bridge-group 10 unicast-flooding
_______
interface Vlan10
 no ip address
 bridge-group 10
___________
interface BVI10
http://www.cisco.com/en/US/docs/routers/access/800/850/software/configuration/guide/wireless.html
regards,
Sebastian
Thanks Sebastian.
your post, at first was disoriented. figured it out latter.....
no luck ! oh and one more thing after a reload the router does not automatically connect to internet, i have to manully got to the atm interface and bring up the interface and same with the wireless also.
as a in info, if this helps below is the sh int vlan10
Vlan10 is up, line protocol is down
  Hardware is EtherSVI, address is dc7b.94f2.d1ae (bia dc7b.94f2.d1ae)
  Description: WiFi
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Last input never, output never, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 packets output, 0 bytes, 0 underruns
     0 output errors, 1 interface resets
     0 unknown protocol drops
attached is the updated config
cadet alain
Does a windows client  with netstumbler sees your AP as protected?
Regards.
Alain.
Yes it does Alain,
The wireless is detected by my laptop which is also wired to the same router and works like charm except for the wireless. I connect to the wireless with the passkey and it shows connected and thats it. No Ip address is assigned to wireless interface and not internet.
your wireless client is not getting an ip address ?
do a debug dhcp server event on router
Regards.
Alain.
Sorry but I see there no difference in the updated config.
but anyhow, vlan 10 protocol is down. The vlan is not working and I think due to that your client will not get an IP. Because you use vlan 10 in the wireless connection.
The VLAN down as long as it is not in use on any physikal interface (access or trunk). Thats what I know from a switch, router, etc..
I think in the cable enviroment evething is working and why do you use not the same on the wireless? Use here vlan 1 too...
Sorry maybe I had to see that much earlier..
- sebastian
@alain
Tried the command to debug dhcp redundancy nothing happened.
@Sebastian
Change vlan 10 to vlan 1, nothing happening.
The ok green light on the router is blinking now, normally blinks and becomes steady lit.
is there any interfaces to be brought up or shutdown or is there any conflict ? Is there anything that can be done from the SDM ?
moshebendahan
hi try this conf
no service pad
no aaa new-model
no ip http server
ip cef
username XXXX
enable secret XXXX
hostname test2
ip dhcp pool LAN
ip dhcp pool WLAN
ip nat inside
channel 8
no shut
ssid My_Wireless
  guest-mode
  authentication open
interface Vlan1
ip nat inside
load-interval 30
hold-queue 100 out
interface Dialer 0
ip nat outside
encapsulation ppp
dialer pool 1
interface ATM0
no ip address
pvc X/X
no shut
line con 0
logging synchronous
login local
line vty 0 4
logging synchronous
login local
OR
no service pad
no aaa new-model
no ip http server
ip cef
ip name-server XXXX
ip name-server XXXX
enable secret XXXX
hostname test1
ip dhcp pool LAN
no ip address
bridge-group 1
channel 8
no shut
ssid My_Wireless
  guest-mode
  authentication open
bridge irb
bridge 1 route ip
interface Vlan1
no ip address
bridge-group 1
interface BVI1
ip nat inside
load-interval 30
hold-queue 100 out
interface Dialer 0
ip nat outside
encapsulation ppp
dialer pool 1
interface ATM0
no ip address
pvc X/X
no shut
line con 0
logging synchronous
login local
line vty 0 4
logging synchronous
login local
Thanks to everyones effort and Moshe, thank you.
Its working and now and here is the config
Current configuration : 2267 bytes
version 12.4
no service pad
hostname R877W
boot-start-marker
boot-end-marker
no logging console
no aaa new-model
dot11 syslog
dot11 ssid Cisco
   authentication open
   guest-mode
ip cef
ip dhcp pool LAN
   domain-name HomeLan
ip dhcp pool Wlan
archive
log config
  hidekeys
bridge irb
interface ATM0
no ip address
pvc 8/35
ip nat inside
ssid Cisco
channel 2447
station-role root
interface Vlan1
ip nat inside
interface Dialer1
ip nat outside
encapsulation ppp
dialer pool 1
ppp chap password 0 qatar12
ppp pap sent-username s4860348 password 0 qatar12
ip http server
control-plane
banner motd ^C
********** HOME ADSL ROUTER **************
****** UNAUTHORISED ACCESS PROHIBITED **** ^C
line con 0
login local
no modem enable
line aux 0
password aux
login
line vty 0 4
password telnet
login
end
well thanks to you guys i got the wireless up and working. one more issue, its the clients take time to get an ip address and the ok light on the routers wireless side is blinking and not steady lit.
how do i get it steady and decrease the time for the clients to receive the ip address, both lan and wifi.
