881 W -A -K9 with 802.11n
Greg Moss
It doesnt have any wireless antenna's. The one I thought I ordered had antenna's is this a extra added accessory i need to order. It appears on the back that there isnt even a place to connect them.
gm
Based on your serial number this box was manufacturered in February 2012.
That's wierd that there's no radio socket.  It's got to be a manufacturing "bug".  I recommend that you raise a TAC Case and send this latest photo to them.  The photo clearly shows that it's a "W" but there's no radio antenna sockets.
9 Replies 9
Leo Laohoo
"sh inventory" will tell you whether or not you ordered the router with or without the WAP.
Thanks for reply!
Its has an embedded AP but no external antenna's. The range is horrible. I do have it set to max power.
Cisco C881W-A-K9 (revision 1.0) with 363596K/29619K bytes of memory.
Processor board ID FTX160584PE
5 FastEthernet interfaces
1 Gigabit Ethernet interface
1 terminal line
1 Virtual Private Network (VPN) Module
1 cisco Embedded AP (s)
DRAM configuration is 32 bits wide
255K bytes of non-volatile configuration memory.
244440K bytes of ATA System CompactFlash (Read/Write)
License Info:
License UDI:
R881#show inventory
NAME: "C881W-A-K9 chassis", DESCR: "C881W-A-K9 chassis"
PID: C881W-A-K9        , VID: V01 , SN: xxxxxxxx
NAME: "C881W Mother board on Slot 0", DESCR: "C881W Mother board"
PID: C881W-A-K9        , VID: V01 , SN: xxxxxxxxx
gm
Turn OFF the radio if you don't have antennas or you'll risk "burning" the transmitters.
Can you take a picture of the back?
One more thing, I need to see the FIRST SEVEN digits (left to right) of your Serial Number.   You can blank out the last four alpha-numeric.
Here you go..........
serial# FTX160584XX
I know..... its the weirdest thing. I have seen a few of these but they all have had antenna's and sockets on the back.
gm
RMA  - replaced. A big oops :-).
gm
Hi Greg,
So you got a replacement but with radio sockets?
