Please help, I can't get Cisco Network Assistant to connect!
rich.schwab
This should be very simple to help me, because I am new to this.  I have a Cisco 2948G switch that I am trying to communicate to through this program. It has both an IP address and is hooked up through a cable. I can get Cisco Network Assistant to come up and ask for it's Username and Password, and that it is where I am stuck!  I have no clue as to what to put in there as a username and password???  I do have a password setup on the switch to login in to it during terminal mode, but that is it.   I simply would like to use this program to make it easier for my home setup.
Thanks!
glen.grant
  Not sure CNA will support a Catos device ,don't see it on the list as a supported device.  You are probably out of luck as far as CNA and that device is concerned.
