887VAM-W-E-K9 AND 800-IL-PM2
alicia.vega
Are 887VAM-W-E-K9 and 800-IL-PM2 compatible? We have got both of them but it seems that router has a 30W power source and module has a 80W power source.
Is there any document to clarify this? Thanks!
Ivan Shirshin
Hi Alicia,
PoE option comes in two parts on 880 routers, the PoE daughter board and a separate power supply.  According to the guide:
"The Cisco 880 series ISRs can include  an optional PoE module that provides power to 802.3af-compliant devices  connected to ethernet ports 0 and 1. If this feature was not configured  with the factory order, SKU 800-IL-PM-2, you must order and install it  to enable the PoE function. The PoE power supply, SKU 800-ILPM-4, is  also required. "
http://www.cisco.com/en/US/docs/routers/access/800/860-880-890/hardware/installation/guide/1Overview880-860.html#wp1176035
Kind Regards,
Ivan
**Please grade this post if you find it useful.
Kind Regards,
Ivan
