8881G-w CDMA activation, help needed
Dear all,
I have a new 8881G-w router with the following info:
(C880DATA-UNIVERSALK9-M), Version 12.4(22)YB2, Serial No. FTX1331830T
I need help in procedure of  activating the CDMA . when I tried to login to the Cellular interface it shows me the following warning:
Warning: 3G Modem is not inserted
Configuration will not be effective until modem is inserted
I want to activate and configure CDMA and i don`t know from to start... can someone help please?????
Reza Sharifi
Do you have the right IOS installed?
The CDMA feature was integrated into the Cisco 880 Series Integrated Service Routers with Cisco IOS Release 15.1(1)T.
Follow the config guide to activate it:
http://www.cisco.com/en/US/docs/routers/access/1800/1861/software/feature/guide/mrwlcdma.html
thanks Reza for responding,
you mean that if i install ios release 15.1, i will not see the following warning:
Router(config)#int cellular 0
Router(config-if)#
- can you explain please what the warning means,, ????
regards,
Hi Mohammed,
Have you found the cause of the issue?
Thank you,
Sebastian
Hi again,
I have install the ios c880data-universalk9-mz.153-1.T_2.bin, but it is still shows me the following:
Router(config-if)#
Can you please see the below if you can help in activation of CDMA,,,
do sh run
Building configuration...
Current configuration : 2529 bytes
version 15.3
no service pad
hostname Router
boot-start-marker
boot system flash:c880data-universalk9-mz.153-1.T_2.bin
boot-end-marker
enable secret 5 $1$Yp3E$kCPwQRpkjp2nSPP5eQ4Gi.
aaa new-model
aaa authentication login default local
--More--                           !
aaa session-id common
memory-size iomem 10
service-module wlan-ap 0 bootimage autonomous
ip cef
no ipv6 cef
ipv6 multicast rpf use-bgp
--More--                           !
license udi pid CISCO881GW-GN-A-K9 sn FTX1331830T
archive
log config
  hidekeys
username aref privilege 15 secret 5 $1$z3TR$SjQF3N2IgiYNRKr4Wj3nI0
controller Cellular 0
track 1 ip sla 1 reachability
csdb tcp synwait-time 30
csdb tcp idle-time 3600
csdb tcp finwait-time 5
csdb tcp reassembly max-memory 1024
csdb tcp reassembly max-queue-length 16
--More--                           csdb udp idle-time 30
csdb icmp idle-time 10
csdb session max-session 65535
interface Tunnel2
ip address 10.10.10.2 255.255.255.0
tunnel source FastEthernet4
tunnel destination 172.30.30.1
interface FastEthernet0
switchport access vlan 2
no ip address
interface FastEthernet1
no ip address
--More--                           !
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
ip address 192.168.1.225 255.255.255.0
duplex auto
speed auto
interface wlan-ap0
description Service module interface to manage the embedded AP
no ip address
arp timeout 0
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
no ip address
interface Cellular0
no ip address
--More--                            encapsulation ppp
interface Vlan1
ip address 192.168.233.20 255.255.255.0
interface Vlan2
ip address 100.100.100.233 255.255.255.0
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 192.168.0.0 255.255.255.0 100.100.100.1 track 1
ip route 0.0.0.0 0.0.0.0 100.100.100.1
ip route 0.0.0.0 0.0.0.0 10.10.10.1 20
ip route 172.23.23.0 255.255.255.0 10.10.10.1
ip route 172.30.30.0 255.255.255.0 192.168.1.10
ip sla auto discovery
ip sla 1
icmp-echo 100.100.100.1 source-interface Vlan2
timeout 1000
--More--                            frequency 5
ip sla schedule 1 life forever start-time now
control-plane
line con 0
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
line 3
no exec
line vty 0 4
transport input all
--More--                           scheduler max-task-time 5000
end
Router(config-if)#do sh ver
Cisco IOS Software, C880 Software (C880DATA-UNIVERSALK9-M), Version 15.3(1)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Mon 26-Nov-12 21:23 by prod_rel_team
ROM: System Bootstrap, Version 12.4(15r)XZ5, RELEASE SOFTWARE (fc1)
Router uptime is 9 minutes
System returned to ROM by reload at 16:40:55 UTC Mon Apr 22 2013
System image file is "flash:c880data-universalk9-mz.153-1.T_2.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
--More--                           to comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 881G (MPC8300) processor (revision 1.0) with 236544K/25600K bytes of memory.
Processor board ID FTX1331830T
5 FastEthernet interfaces
1 Gigabit Ethernet interface
3 terminal lines
1 Virtual Private Network (VPN) Module
1 Cellular interface
1 cisco Embedded AP (s)
256K bytes of non-volatile configuration memory.
125440K bytes of ATA CompactFlash (Read/Write)
License Info:
--More--
License UDI:
Device#      PID            SN
*0        CISCO881GW-GN-A-K9    FTX1331830T
License Information for 'c880-data'
    License Level: advipservices   Type: Permanent
    Next reboot license Level: advipservices
Router(config-if)#do sh flash:
-#- --length-- -----date/time------ path
1     38300572 Apr 22 2013 16:39:48 +00:00 c880data-universalk9-mz.153-1.T_2.bin
2         3472 Jul 31 2009 15:50:40 +00:00 cpconfig-8xxW.cfg
3      2324992 Jul 31 2009 15:50:54 +00:00 cpexpress.tar
4         1038 Jul 31 2009 15:51:02 +00:00 home.shtml
5       115712 Jul 31 2009 15:51:10 +00:00 home.tar
6      1697952 Jul 31 2009 15:52:22 +00:00 securedesktop-ios-3.1.1.45-k9.pkg
7       415956 Jul 31 2009 15:52:34 +00:00 sslclient-win-1.1.4.176.pkg
8          660 Mar 2 2013 16:53:18 +00:00 vlan.dat
85409792 bytes available (42876928 bytes used)
Router(config-if)#
