891 with multiple vlans and dhcp problem
Victor Martins
My scenario: A 891 is linked to a 2960 switch. I have 2 vlan.
My problem: if I put an ip on the vlan the dhcp works on the 891 but stops on the 2960, if I put the ip on the sub interface, the dhcp work on the swicth, but the switch on the 891 never gives ip's.
My configurations:
Switch 2960
no service pad
hostname SWT1-Biblioteca
no aaa new-model
system mtu routing 1500
spanning-tree mode pvst
vlan internal allocation policy ascending
interface range FastEthernet0/1-3
switchport trunk allowed vlan 1-3
switchport mode trunk
interface FastEthernet0/4
switchport access vlan 2
switchport mode access
spanning-tree portfast
interface FastEthernet0/5
interface FastEthernet0/6
switchport access vlan 3
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
switchport trunk native vlan 2
switchport trunk allowed vlan 2,3
interface GigabitEthernet0/2
interface Vlan1
ip address 10.5.2.1 255.255.255.248
interface Vlan2
ip address 172.21.1.254 255.255.255.0
interface Vlan3
no ip address
no ip http server
no ip http secure-server
access-list 2 permit 172.21.1.1
access-list 2 deny   any
line con 0
login local
line vty 0 4
access-class 2 in
login local
line vty 5 15
access-class 2 in
login local
ntp clock-period 36028732
ntp source Vlan2
ntp server 172.21.1.1
end
My router:
version 15.0
hostname rt-hotspot
boot-start-marker
boot-end-marker
no aaa new-model
clock timezone GMT 0
clock summer-time GMT recurring
ip source-route
ip dhcp excluded-address 172.20.1.254
ip dhcp excluded-address 192.168.2.1
ip dhcp excluded-address 172.21.1.1
ip dhcp excluded-address 172.21.1.253
ip dhcp excluded-address 172.21.1.254
ip dhcp pool hotspots
   network 172.20.0.0 255.255.0.0
   default-router 172.20.1.254
   dns-server 8.8.8.8
   lease 0 3
ip dhcp pool biblioteca
   network 172.21.1.0 255.255.255.0
   default-router 172.21.1.1
   dns-server 8.8.8.8
   lease 5
ip dhcp pool biblioteca-hotspot
   network 192.168.2.0 255.255.255.0
   default-router 192.168.2.1
   dns-server 8.8.8.8
   lease 0 3
ip cef
no ipv6 cef
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
switchport access vlan 10
interface FastEthernet8
no ip address
shutdown
duplex auto
speed auto
description LAN$FW_INSIDE$
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
no ip route-cache cef
no ip route-cache
duplex auto
speed auto
interface GigabitEthernet0.1
encapsulation dot1Q 1
no ip route-cache
interface GigabitEthernet0.2
encapsulation dot1Q 2 native
no ip route-cache
bridge-group 2
bridge-group 2 spanning-disabled
interface GigabitEthernet0.3
encapsulation dot1Q 3
ip address 192.168.2.1 255.255.255.0
ip nat inside
ip virtual-reassembly
no ip route-cache
ip tcp adjust-mss 1452
interface Vlan1
ip address 172.20.1.254 255.255.0.0
ip nat inside
interface Vlan2
ip address 172.21.1.1 255.255.255.0
ip nat inside
no ip route-cache
bridge-group 2
interface Vlan3
no ip address
interface Vlan10
description Internet
ip address *.*.*.* 255.255.254.0
ip nat outside
no ip route-cache
interface Async1
no ip address
encapsulation slip
ip forward-protocol nd
no ip http server
ip http authentication local
ip nat inside source list 1 interface Vlan10 overload
ip route 0.0.0.0 0.0.0.0 195.54.168.3
access-list 1 permit 172.20.0.0 0.0.255.255
access-list 1 permit 172.21.1.0 0.0.0.255
access-list 1 permit 192.168.2.0 0.0.0.255
access-list 1 deny   any
control-plane
line con 0
login local
line 1
modem InOut
stopbits 1
speed 115200
flowcontrol hardware
line aux 0
line vty 0 4
access-class 2 in
login local
line vty 5 15
access-class 2 in
login local
scheduler max-task-time 5000
ntp source Vlan10
ntp master
ntp update-calendar
ntp server 194.117.9.130 prefer source Vlan10
end
Any ideias?
0 Replies 0
