897VAM - power supply for PoE support
I wanted to add PoE option to one of my ISR 897 VAM routers. So after googling and looking though all the documentation the datasheet for the 890 series router i ordered the 800-IL-PM-4.
After installation of the daughter card I realised that to get this to work, the unit will need a powersupply with both 12VDC and 54VDC voltage, or a 125W powersupply as it's seems to be caled.
Do any one know where to find part number for this powersupply?
Best regards,
Johan Christensson
Martin Dugre
My customer had the same issue, the SKU is PWR-125W-AC=
