NAT Error Message: %Port 23 is being used by system
I am in the process of configuring a router and while deploying some of the NAT translations I ran into a problem.
router(config)#ip nat inside source static tcp 10.0.20.105 22 interface gigabitEthernet 1/1 23
router(config)#do clear ip nat trans forced
Telnet is not enabled, and clearing the nat translations did not fix the problem.  Anyone have any ideas?
Thanks!
Bump.... this was opened during Cisco's maintenance window.
I have the same issue on 6504-E with IOS version s72033-adventerprisek9-mz.151-2.SY2.bin.
you fixed the problem?
Sergio
