9200 channel-misconfig error detected
weicloud_chw
Hello
I want replace core switch(alcatel 9702e -> cisco nexus 9508),there have 3 edge switch (cisco Catalyst 9200)
when I connect cisco nexus  9508 to  alcatel 9702e ,edge switch 9200 got error
the old network topology is
(alcatel 9702e) - (alcatel 6900) - (cisco Catalyst 9200)
new network topology is
( cisco nexus 9508) - (alcatel 9702e) - (alcatel 6900) - (cisco Catalyst 9200)
9200 uplink is Te1/1/1-Te1/1/2
config use
channel-group 1 mode on active
and cisco Catalyst 9200 the error log
*Jul 17 19:05:56.588: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/18, changed state to up
*Jul 17 19:12:00.770: %SEC_LOGIN-5-LOGIN_SUCCESS: Login Success [user: admin] [Source: 10.2.85.60] [localport: 22] at 03:12:00 taipei Sun Jul 18 2021
*Jul 17 19:12:24.945: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 192.168.49.241 port 0 CLI Request Triggered
*Jul 17 19:12:25.945: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 192.168.49.241 port 514 started - CLI initiated
*Jul 17 19:12:26.849: %SYS-5-CONFIG_I: Configured from console by admin on vty0 (10.2.85.60)
*Jul 17 19:12:31.625: %SYS-6-LOGOUT: User admin has exited tty session 2(10.2.85.60)
*Jul 17 19:22:10.650: %SMART_LIC-5-SYSTEM_CLOCK_CHANGED: Smart Agent for Licensing System clock has been changed
Jul 17 19:23:09.648: %PKI-6-AUTHORITATIVE_CLOCK: The system clock has been set.
.Jul 17 19:31:42.845: %SMART_LIC-5-SYSTEM_CLOCK_CHANGED: Smart Agent for Licensing System clock has been changed
Jul 17 19:35:19.605: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/18, changed state to down
Jul 17 19:35:20.608: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/18, changed state to down
Jul 17 19:35:23.278: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/18, changed state to up
Jul 17 19:35:24.278: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/18, changed state to up
Jul 17 19:35:32.657: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/18, changed state to down
Jul 17 19:35:33.662: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/18, changed state to down
Jul 17 19:35:36.898: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/18, changed state to up
Jul 17 19:35:37.898: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/18, changed state to up
.Jul 17 19:42:02.702: %SMART_LIC-5-SYSTEM_CLOCK_CHANGED: Smart Agent for Licensing System clock has been changed
Jul 17 19:47:58.239: %PM-4-ERR_DISABLE: channel-misconfig error detected on Po1, putting Te1/1/1 in err-disable state
Jul 17 19:47:58.271: %PM-4-ERR_DISABLE: channel-misconfig error detected on Po1, putting Te1/1/2 in err-disable state
Jul 17 19:47:58.279: %PM-4-ERR_DISABLE: channel-misconfig error detected on Po1, putting Po1 in err-disable state
Jul 17 19:47:59.248: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/1/1, changed state to down
Jul 17 19:47:59.271: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/1/2, changed state to down
Jul 17 19:47:59.271: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel1, changed state to down
Jul 17 19:48:00.253: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/1/1, changed state to down
Jul 17 19:48:00.273: %LINK-3-UPDOWN: Interface Vlan49, changed state to down
.Jul 17 19:48:00.276: %LINK-3-UPDOWN: Interface Port-channel1, changed state to down
.Jul 17 19:48:00.278: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/1/2, changed state to down
.Jul 17 19:48:01.272: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan49, changed state to down
.Jul 17 19:57:19.803: %SEC_LOGIN-5-LOGIN_SUCCESS: Login Success [user: admin] [Source: LOCAL] [localport: 0] at 03:57:19 taipei Sun Jul 18 2021
.Jul 17 19:57:38.392: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/1/1, changed state to up
.Jul 17 19:57:38.556: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/1/2, changed state to up
.Jul 17 19:57:39.888: %SYS-5-CONFIG_I: Configured from console by admin on console
.Jul 17 19:57:43.440: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/1/1, changed state to up
.Jul 17 19:57:43.630: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/1/2, changed state to up
.Jul 17 19:57:44.437: %LINK-3-UPDOWN: Interface Port-channel1, changed state to up
.Jul 17 19:57:45.437: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel1, changed state to up
.Jul 17 19:57:47.681: %LINK-3-UPDOWN: Interface Vlan49, changed state to up
.Jul 17 19:57:48.680: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan49, changed state to up
C9200L-48T-3E-1#$
.Jul 17 19:59:18.515: %SMART_LIC-5-SYSTEM_CLOCK_CHANGED: Smart Agent for Licensing System clock has been changedshow
alcatel 6900 log
2021 Jul 18 03:47:53 6900-X72-A3 swlogd: linkAggCmm main info(5) Leave Req agg:55 port:2/1/19(131090)
2021 Jul 18 03:47:53 6900-X72-A3 swlogd: linkAggCmm main info(5) la_cmm_mgt_rcv_port_leave_req_f Agg Id: 55 MAC: 2c:fa:a2:cb:ad:5a
2021 Jul 18 03:47:53 6900-X72-A3 swlogd: linkAggNi main info(5) la_ni_mgt_port_leave_f Agg Id: 55 Primary port: 1/1/19(18)
2021 Jul 18 03:47:53 6900-X72-A3 swlogd: linkAggCmm main info(5) la_cmm_mgt_rcv_port_leave_req_f updated Agg Id: 55 MAC: 2c:fa:a2:cb:ad:5a
2021 Jul 18 03:47:53 6900-X72-A3 swlogd: linkAggCmm main info(5) la_cmm_mgt_rcv_port_leave_req_f Agg Id: 55 New Primary port: 1/1/19(1019)
2021 Jul 18 03:47:53 6900-X72-A3 swlogd: portMgrCmm main info(5) : [pmProcessLagMsgs:251] PORT_LEAVE: agg:55 port:131090 prim:18
2021 Jul 18 03:47:53 6900-X72-A3 swlogd: linkAggCmm main info(5) Port Leave .LACP port: 2/1/19(101019) agg: 55 link:UP agg_admin:UP timedout:TRUE
2021 Jul 18 03:47:53 6900-X72-A3 swlogd: vfcm main info(5) [vfccQsHandleLagEvents:1088] VFCC :: LA_PORT_LEAVE_CODE: agg 2000037 port 131090
2021 Jul 18 03:47:53 6900-X72-A3 swlogd: linkAggCmm main info(5) UnReserve Req port:2/1/19(131090)
2021 Jul 18 03:47:53 6900-X72-A3 swlogd: linkAggCmm main info(5) Selection Req agg:-1 port:2/1/19(131090)
2021 Jul 18 03:47:53 6900-X72-A3 swlogd: linkAggCmm main info(5) la_cmm_mgt_lacp_port_unselection_f: Agg Id:55 Port:2/1/19(101019) Deleted from Agg port table
2021 Jul 18 03:47:53 6900-X72-A3 swlogd: portMgrNi main info(5) : [pmProcessLagMsgs:251] PORT_LEAVE: agg:55 port:131090 prim:18
2021 Jul 18 03:47:53 6900-X72-A3 swlogd: linkAggNi main warning(4) Sync Out port=1/1/19(18) partner:Out actor:Out Dist Coll NotSelected Attached
2021 Jul 18 03:47:53 6900-X72-A3 swlogd: vfcn main info(5) [vfccQsHandleLagEvents:1088] VFCC :: LA_PORT_LEAVE_CODE: agg 2000037 port 131090
2021 Jul 18 03:47:53 6900-X72-A3 swlogd: linkAggNi main info(5) la_ni_agg_lacp_deselect_agg_f: Agg Id:55 Port:2/1/19(101019) Deleted from Agg port table
2021 Jul 18 03:47:53 6900-X72-A3 swlogd: linkAggCmm main info(5) Leave Req agg:55 port:1/1/19(18)
2021 Jul 18 03:47:53 6900-X72-A3 swlogd: stpNi _AGRt info(5) LA_PORT_LEAVE: agg_id=55 port_id=x20012 prim_port_id=x12
2021 Jul 18 03:47:53 6900-X72-A3 swlogd: svcNi mSVC info(5) MNID:LAG:: LA_PORT_LEAVE gport 131090 pri-port 18 for aggId 55
2021 Jul 18 03:47:53 6900-X72-A3 swlogd: portMgrCmm main info(5) : [pmProcessLagMsgs:288] AGG_DOWN agg:55 last_port:18
2021 Jul 18 03:47:53 6900-X72-A3 swlogd: stpCmm _AGRt info(5) LA_AGGDOWN agg_ifdx=40000055
2021 Jul 18 03:47:53 6900-X72-A3 swlogd: vfcm main info(5) [vfccQsHandleLagEvents:1021] VFCC :: AGG DOWN : agg 2000037 port (1/19) 18 : 8
2021 Jul 18 03:47:53 6900-X72-A3 swlogd: linkAggCmm main info(5) Aggregate Down. LACP port: 1/1/19(1019) agg: 55 link:UP agg_admin:UP timedout:TRUE
2021 Jul 18 03:47:53 6900-X72-A3 swlogd: linkAggCmm main info(5) UnReserve Req port:1/1/19(18)
2021 Jul 18 03:47:53 6900-X72-A3 swlogd: portMgrNi main info(5) : [pmProcessLagMsgs:288] AGG_DOWN agg:55 last_port:18
2021 Jul 18 03:47:53 6900-X72-A3 swlogd: linkAggNi main info(5) la_ni_agg_lacp_deselect_agg_f: Agg Id:55 Port:1/1/19(1019) Deleted from Agg port table
2021 Jul 18 03:47:53 6900-X72-A3 swlogd: svcNi mSVC info(5) MNID:LAG:: LA_AGG_DOWN for aggId 55 last-port 18
2021 Jul 18 03:47:53 6900-X72-A3 swlogd: vfcn main info(5) [vfccQsHandleLagEvents:1021] VFCC :: AGG DOWN : agg 2000037 port (1/19) 18 : 8
2021 Jul 18 03:47:53 6900-X72-A3 swlogd: linkAggCmm main info(5) Selection Req agg:55 port:1/1/19(18)
2021 Jul 18 03:47:53 6900-X72-A3 swlogd: stpNi _AGRt info(5) LA_AGG_DONW: agg_id=55 last_port_id=x12
2021 Jul 18 03:47:53 6900-X72-A3 swlogd: linkAggCmm main info(5) la_cmm_mgt_lacp_port_unselection_f: Agg Id:55 Port:1/1/19(1019) Deleted from Agg port table
2021 Jul 18 03:47:53 6900-X72-A3 swlogd: linkAggCmm main info(5) la_cmm_agg_lacp_select_agg_f: Agg Id:55 Port:1/1/19(1019) Added into Agg port table
2021 Jul 18 03:47:53 6900-X72-A3 swlogd: linkAggNi main info(5) la_ni_agg_lacp_select_agg_f: Agg Id:55 Port:1/1/19(1019) Added into Agg port table
2021 Jul 18 03:47:53 6900-X72-A3 swlogd: linkAggCmm main info(5) Reserve Req port:1/1/19(18)
2021 Jul 18 03:47:53 6900-X72-A3 swlogd: intfCmm Mgr info(5) cmmEsmUpdateLinkStatus: INTERFACE 2/1/19 LINK DOWN
2021 Jul 18 03:47:53 6900-X72-A3 swlogd: portMgrCmm main info(5) : [pmVcPeerProcessLinkStatusFromPeer:1381] LINKSTS gport 0x20012, state 0
2021 Jul 18 03:47:53 6900-X72-A3 swlogd: ^^ repeated 1 times
2021 Jul 18 03:47:53 6900-X72-A3 swlogd: intfCmm Mgr info(5) cmmEsmHandleNiMsg: Rx CMM_ESM_LINK_STATUS_CHG from chassis 2 NI 1
2021 Jul 18 03:47:53 6900-X72-A3 swlogd: linkAggCmm main info(5) Linkstate : port 2/1/19(131090) is DOWN
2021 Jul 18 03:47:53 6900-X72-A3 swlogd: linkAggCmm main info(5) Cmm Sync Linkstate : port 2/1/19(131090)
2021 Jul 18 03:47:53 6900-X72-A3 swlogd: ip6nid library(plApi) error(2) plIsGportValid@12781: Invalid port type 2 (gport 33554487)
2021 Jul 18 03:47:53 6900-X72-A3 swlogd: portMgrNi main info(5) : [pmnHALLinkStatusCallback:216] LINKSTS 1/1/19 DOWN (gport 0x12) Speed 0 Duplex HALF
2021 Jul 18 03:47:53 6900-X72-A3 swlogd: intfNi Drv info(5) niEsmHandleEvent: current NI state:RUNNING event:8, sourceChassisId 0 sourceSlotum 0
2021 Jul 18 03:47:53 6900-X72-A3 swlogd: intfNi Drv info(5) niEsmSendLinkStatusChgMsg(868): linkstatus DOWN sent on peerId=1
2021 Jul 18 03:47:53 6900-X72-A3 swlogd: vfcn main info(5) [vfccQsHandleLinkEvents:488] 1/1/19 LINK DOWN
2021 Jul 18 03:47:53 6900-X72-A3 swlogd: stpNi _SOKt info(5) stpnimsg_processMsgFromPM: PM_LINK_STATUS_MSGID gPort=x12 linkStatus=0
2021 Jul 18 03:47:53 6900-X72-A3 swlogd: intfCmm Mgr info(5) cmmEsmUpdateLinkStatus: INTERFACE 1/1/19 LINK DOWN
2021 Jul 18 03:47:53 6900-X72-A3 swlogd: intfCmm Mgr info(5) cmmEsmHandleNiMsg: Rx CMM_ESM_LINK_STATUS_CHG from chassis 1 NI 1
2021 Jul 18 03:47:53 6900-X72-A3 swlogd: linkAggNi main info(5) la_ni_mgt_rcv_pm_link_down_f: send link down state to cmm 1/1/19(18)
2021 Jul 18 03:47:53 6900-X72-A3 swlogd: linkAggCmm main info(5) Linkstate : port 1/1/19(18) is DOWN
2021 Jul 18 03:47:53 6900-X72-A3 swlogd: linkAggCmm main info(5) Cmm Sync Linkstate : port 1/1/19(18)
2021 Jul 18 03:47:53 6900-X72-A3 swlogd: linkAggNi main info(5) LACP Link 1/1/19(18) -> 0 is OUT_OF_SYNC agg=-1
2021 Jul 18 03:47:53 6900-X72-A3 swlogd: linkAggNi main info(5) 1/1/19(18) State Actor:Actv Fast Aggr Out . . Deflt . Partner:Pass Slow Aggr Out Coll Dist Deflt .
2021 Jul 18 03:47:53 6900-X72-A3 swlogd: linkAggCmm main info(5) Selection Req agg:-1 port:1/1/19(18)
2021 Jul 18 03:47:55 6900-X72-A3 swlogd: VlanMgrNi main error(2) vmUpdateVpaState@3609-> Attempted to update state change for physical port which is part of LAG
2021 Jul 18 03:47:55 6900-X72-A3 swlogd: VlanMgrNi main info(5) vmUpdateVpaState@3690-->Not updating the Vpa state as the link is down
2021 Jul 18 03:47:55 6900-X72-A3 swlogd: VlanMgrNi main info(5) VM-NI-VPA-EVENT>vmUpdateVpaState@3692-> ifIndex=40000055 vid=49 vpaState=1 remote:0 gen evt:1
2021 Jul 18 03:47:55 6900-X72-A3 swlogd: VlanMgrNi main info(5) VM-NI-VPA-EVENT>vmUpdateVpaState@3692-> ifIndex=40000055 vid=550 vpaState=1 remote:0 gen evt:1
2021 Jul 18 03:47:55 6900-X72-A3 swlogd: VlanMgrNi main info(5) VM-NI-VPA-EVENT>vmUpdateVpaState@3692-> ifIndex=40000055 vid=570 vpaState=1 remote:0 gen evt:1
2021 Jul 18 03:47:55 6900-X72-A3 swlogd: VlanMgrNi main info(5) VM-NI-VPA-EVENT>vmUpdateVpaState@3692-> ifIndex=40000055 vid=610 vpaState=1 remote:0 gen evt:1
2021 Jul 18 03:47:55 6900-X72-A3 swlogd: VlanMgrNi main info(5) VM-NI-VPA-EVENT>vmUpdateVpaState@3692-> ifIndex=40000055 vid=620 vpaState=1 remote:0 gen evt:1
2021 Jul 18 03:47:55 6900-X72-A3 swlogd: VlanMgrNi main info(5) VM-NI-VPA-EVENT>vmUpdateVpaState@3692-> ifIndex=40000055 vid=830 vpaState=1 remote:0 gen evt:1
2021 Jul 18 03:47:58 6900-X72-A3 swlogd: linkAggNi main warning(4) Sync Out port=1/1/20(19) partner:Out actor:Out Dist Coll NotSelected Attached
2021 Jul 18 03:47:58 6900-X72-A3 swlogd: linkAggCmm main info(5) Leave Req agg:56 port:1/1/20(19)
I don't have change alcatel 6900、cisco 9200 config、toplogy ,just connect cisco 9508 to alcatel 9702e
why the 9200 port will got  "channel-misconfig error detected" ?
how do I resolve ?
balaji.bandi
is this going down and up in loop or only when the nexus switch connected time (one time only)
how is you spanning treee configured. ?
BB
I use default spanning tree config
it's strange
all edge switch work fine
only 9200 have error
