9300 Switch Interface Identification
avilt
Level 7
Level 7
I have two 9300 switches in stack and I found the following interfaces in the config. Physically I have only 24LAN ports and nothing else. Where are these interfaces and can I disable them? Also what is AppGigabitEthernet? Can I disable this too?
interface GigabitEthernet1/1/1 - 4
interface TenGigabitEthernet1/1/1 - 8
interface FortyGigabitEthernet1/1/1 - 2
interface TwentyFiveGigE1/1/1 - 2
interface AppGigabitEthernet1/0/1
Leo Laohoo
Those are the optional network module.
In the past, if the network module were not installed, you would not "see" them.  Unfortunately, some people got upset and "complained" so Cisco changed the codes to "reflect" the network modules to make it easy to pre-configure the ports.
If you are not using them, you may disable them.
can I disable software port AppGigabitEthernet as well?
You can.
