9300 switch license issue (not license smart register idtoken)
Omar49584
Hi ,
I am currently having an issue with 9300 Stack of switches running IOSXE Amsterdam.
I have followed the procedure on cisco's website "System Management Configuration Guide, Cisco IOS XE Amsterdam 17.3.x (Catalyst 9300 Switches) - Configuring Smart Licensing [Support] - Cisco"
After changing the license boot level using  "license boot level network-essentials addon dna-essential"
I can see that the switch has taken the command after the reboot I get the following output when running "sh ver"
Technology Package License Information:
Technology-package Technology-package
Current Type Next reboot
network-essentials Smart License network-essentials
dna-essentials Subscription Smart License dna-essentials
However when going to the next level to apply "license smart register idtoken" the switch does not even show the option for register when I try and run "license smart ?
6 Replies 6
balaji.bandi
as per the informaiton you already have license installed ?
post full output :
# show license all
BB
Please find the output below:
Smart Licensing Status
Smart Licensing is ENABLED
Export Authorization Key:
Features Authorized:
<none>
Utility:
Status: DISABLED
Smart Licensing Using Policy:
Status: ENABLED
Data Privacy:
Sending Hostname: yes
Callhome hostname privacy: DISABLED
Smart Licensing hostname privacy: DISABLED
Version privacy: DISABLED
Transport:
Type: cslu
Cslu address: <empty>
Proxy:
Not Configured
Miscellaneous:
Custom Id: <empty>
Policy:
Policy in use: Merged from multiple sources.
Reporting ACK required: yes (CISCO default)
Unenforced/Non-Export Perpetual Attributes:
First report requirement (days): 365 (CISCO default)
Reporting frequency (days): 0 (CISCO default)
Report on change (days): 90 (CISCO default)
Unenforced/Non-Export Subscription Attributes:
First report requirement (days): 90 (CISCO default)
Reporting frequency (days): 90 (CISCO default)
Enforced (Perpetual/Subscription) License Attributes:
First report requirement (days): 0 (CISCO default)
Report on change (days): 0 (CISCO default)
Export (Perpetual/Subscription) License Attributes:
Usage Reporting:
Last ACK received: <none>
Next ACK deadline: Dec 07 16:17:28 2021 UTC
Reporting push interval: 30 days
Next ACK push check: <none>
Next report push: Sep 24 09:00:52 2021 UTC
Last report push: <none>
Last report file write: <none>
Trust Code Installed: <none>
License Usage
network-essentials (C9300L 24P Network Essentials):
Description: C9300L 24P Network Essentials
Count: 2
Version: 1.0
Status: IN USE
Export status: NOT RESTRICTED
Feature Name: network-essentials
Feature Description: C9300L 24P Network Essentials
Enforcement type: NOT ENFORCED
License type: Perpetual
dna-essentials (C9300L 24P DNA Essentials):
Description: C9300L 24P DNA Essentials
Count: 2
Version: 1.0
Status: IN USE
Feature Name: dna-essentials
Feature Description: C9300L 24P DNA Essentials
License type: Subscription
Product Information
UDI: PID:C9300L-24T-4X,SN:FOC2509L7HY
HA UDI List:
Active:PID:C9300L-24T-4X,SN:FOC2509L7HY
Standby:PID:C9300L-24T-4X,SN:FOC2509L7HD
Agent Version
Smart Agent for Licensing: 5.0.9_rel/68
License Authorizations
Overall status:
Active: PID:C9300L-24T-4X,SN:FOC2509L7HY
Status: NOT INSTALLED
Standby: PID:C9300L-24T-4X,SN:FOC2509L7HD
Purchased Licenses:
No Purchase Information Available
Derived Licenses:
Entitlement Tag: regid.2018-06.com.cisco.C9300L_24P_NW_Essentials,1.0_0069ac2f-fa49-4765-a6a4-ab495e5ebe5e
Entitlement Tag: regid.2018-06.com.cisco.C9300L_24P_DNA_Essentials,1.0_2ac0b388-b338-40f0-a311-dc53a9da9f78
Just to highlight this is IOSXE  17.03.04 . is the update process on it any different ?
post the full running configuration of the 9300. Is your call home fully working ?
Which sections of the config are you interested in as I am not allowed to paste the full thing here for confidentiality.
I forgot to mention that this is IOSXE  17.03.04  . is the process any different on the newer versions ?
I have seen few posts about using CSLU but no official cisco guide on that.
mgrabovs
Starting from IOS-XE 17.3.2, the smart licensing imposed is SLUP (Smart Licensing Using Policy), where there is no more the concept of registering the device.
For more information and examples of different methods of configuration of SLUP, you can check the documentation below:
Smart Licensing using Policy on Catalyst Switching Platforms
Thank you.
Marin Grabovschi
