Hello. I am a newbie network engineer that has been asked to set up a VSS (one logical switch) from two C9500-16X-A switches. They will connect back to two different back bone connections and have 5 downstream access switches. I am dealing with 10 Gig optics for all connections.
What is your question?
The 9500 series support Virtual Stacking, which is another name for VSS.
here is the resource for you to setup one you looking :
