Showing results forĀ
Search instead forĀ
Did you mean:Ā
9500 32qc virtual stackwise bonding issue
naresh86
Visitor
we try to to deploy 2 9500 32qc switch in virtual stackwise configuration. configuration ran smoothly without any issues but after reload each switch cant find other switch to bond. i followed below configuration
stackwise virtual
domain 10
int fo1/0/16
stackwise virtual link 1
int fo1/0/17
stackwise-virtual dual-active-detection
wr
reload
on both switches
i tried stack cables to connect same port numbers on each switches and later changed to other port numbers
on show results each switch showing their fo1/0/16 ports only
We raised TAC case for this. TAC engineer tried different port 1/45, 46 & 48. Its started to work. there is no technical reason from him why it didnt workout with other ports. L1 should be up before we confiure the ports
7 Replies 7
Reza Sharifi
Can you post the output of "sh run" from both switches?
int fo1/0/16
According to the above config, you have only configured 1/0/16 for the SVL.
Please find sh run attachments below
lagerplane
Level 3
Level 3
Are your Fo1/0/16 and Fo1/0/17 native 40G or 100G ports. The configuration guide says "On C9500-32QC, you can configure SVL and DAD only on native 100G and 40G interfaces (default configuration ports). You cannot configure SVL and DAD on converted 100G and 40G interfaces."
High Availability Configuration Guide, Cisco IOS XE Amsterdam 17.3.x (Catalyst 9500 Switches)
Chapter: Configuring Cisco StackWise Virtual | Restrictions for Cisco StackWise Virtual
Restrictions for Cisco Catalyst 9500 Series High Performance Switches
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9500/software/release/17-3/configuration_guide/ha/b_173_ha_9500_cg/configuring_cisco_stackwise_virtual.html#reference_kph_hgh_nlb
Also, adding these known SVL related issues, these might not be related to your issue but still have a quick look.
Cat9500 High Performance - SVL not supported on 16.9 code
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvo77544
Some C9500 switches shipped from mfg have incorrect MAC_ADDR programmed in rommon/bootloader
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvx58338
yes, when i try to configure on hundredgiga it displayed that non native port message. than i switched other port and found no issues in configuration
lagerplane
Level 3
Level 3
The configurations look good. Which SFPs are you using on the Fo1/0/16 and Fo1/0/17 ? please share the SFP exact model and VID (version ID) for all 4 ports.
Also, when you power on both Switches with the SVL link (Fo1/0/16---Fo1/0/16) connected, the issue that you see is that both Fo1/0/16 on each end remains down/down?
Could you share all console outputs from both Switches when you power them on with the SVL link connected ?
its 40g/100g qsfp+ to 40g/100g qsfp+ cables from cisco. i will send you reports on monday
