sbyrne
hello we have 2 x 9500 in a Stackwise topology
recently we had a failure where the  2x SVL interfaces and the Dual Active Detection link failed
therefore the switches went Dual Active
in the logs there were
"Error reading DOM data from transceiver"
this error occurred against all the interfaces around 3 hours before the Dual Active condition
we run 16.12.3a -- I thought this type of  DOM error were fixed in this version
Q has anyone seen similar behaviour
This bug have a very good match with your problem.
https://bst.cisco.com/bugsearch/bug/CSCvk33624
I recommend you  to upgrade do version 17.x.x.
?thank you
I looked at this bug ID earlier
I thought it had been fixed in version 16.12.3a on our switches
I agree on your suggestion to upgrade
In fact, 16.12.3a is listed on the fixed release. But, as the logs describes very closely the Bug behavior and considering that sometimes Bug persists after cisco anoucing the solution of it, I suggest upgrade as start.  Version 16 is already a bit older so doesn´t hurt upgrade to 17.
?thank you
