06-23-2021 10:10 AM
We are getting power deny on the line card modules for a newly ordered 9606R as below. How to resolve this?
SW1#sh mod
Chassis Type: C9606R
Mod Ports Card Type Model Serial No.
2 48 48-Port 10GE / 25GE C9600-LC-48YL FDxxxxxxxx
3 0 Supervisor 1 Module C9600-SUP-1 FDxxxxxxxx
4 0 Supervisor 1 Module C9600-SUP-1 FDxxxxxxxx
5 48 48-Port 10GE and MGIG COPPER C9600-LC-48TX FDxxxxxxxx
Mod MAC addresses Hw Fw Sw Status
2 xxxx.xxxx.xxxx to xxxx.xxxx.xxxx 1.2 17.3.1r[FC2] 17.03.03 power-deny
3 xxxx.xxxx.xxxx to xxxx.xxxx.xxxx 1.3 17.3.1r[FC2] 17.03.03 ok
4 xxxx.xxxx.xxxx to xxxx.xxxx.xxxx 1.3 17.3.1r[FC2] 17.03.03 ok
5 xxxx.xxxx.xxxx to xxxx.xxxx.xxxx 1.1 17.3.1r[FC2] 17.03.03 power-deny
Mod Redundancy Role Operating Redundancy Mode Configured Redundancy Mode
3 Active sso sso
4 Standby sso sso
Chassis MAC address range: 64 addresses from xxxx.xxxx.xxxx
06-23-2021 11:14 AM
Hi @adeebtaqui ,
You probably do not have enough power available.
"show power detail" will give you all the information you need about the power supply installed, the amount of Watts available and the power budget for each module.
06-23-2021 03:20 PM
Agree with @Harold Ritter and there may not be enough power.
Also, have a look at the logs. When the line cards get inserted, there logs should display the boot-up of the line cards as well as any errors subsequent to the insert. Those logs will be very vital in the troubleshooting.
