A few questions on NAT
grichardson661
I'm currently working with NAT ready for my CCNA next week. I read up on NAT last night but have a few questions.
Lets say you have this scenario.
interface s0/0
ip nat outside
ip address 98.65.12.5 255.255.255.252
interface Ethernet 0
ip nat inside
ip nat inside source list 50 serial 0/0
access-list 50 permit 192.168.1.0 0.0.0.255
This configuration would only allow one host out at a one time that has an IP address that falls within the permit statement and because I have not overloaded it right?
If somebody on the outside was to ping 98.65.12.5, this would not be translated to an internal address because I haven't created static NAT entry, the packet would be dropped?
Lets say, if I add 'ip nat inside source static 192.168.1.4 20 98.65.12.5' and a host from the outside pinged 98.65.12.5, this would be translated and forwarded to 192.168.0.4 and this would also work vice versa?
Last of all,
If I created a pool of address, let's say from 200.200.0.1 200.200.0.7 255.255.255.248 and I configured the NAT statement with OUT overload, only 7 connections would be able get to the internet right using the pool of addresses, but if I overloaded the NAT statement, each IP address from the pool statement would be able to work with every available port number if needed?
Garry
Marwan ALshawi
for ur first question u were right
for next question u were right but for ping if u ping the router external ip and u dont have static nat this ping wil not droped because u pinging the router unless u have an ACL deny it
for third question u were right as well
for last question if u have overload with those 7 IPs in the pool the pool will be used once it reach the last one it gonna make PATing ovelroading using ports as u stated :)
good luck in ur CCNA exam
if helpful Rate
Thanks for your reply! Very helpful!
Regarding the pool addresses, the last scenario. Just to clear this up, lets say for simplicity reasons there are a total of 5 ports available for PAT(overload) and i have configured a NAT pool of 7 IPs.
So would the first nat transactions for the first IP address in NAT pool go like..
200.200.0.1:1
200.200.0.1:2
200.200.0.1:3
200.200.0.1:4
200.200.0.1:5
And then, next IP in the NAT pool...
200.200.0.2:1
200.200.0.2:2
200.200.0.2:3
200.200.0.2:4
200.200.0.2:5
And so on...
Garry
