A power source cdamage a Switch?
dani_corunda
My question is I have a WS-C3750X-24P-L and I see by its characteristics that it supports a C3KX-PWR-715WAC power source, if a C3KX-PWR-1100WAC power source is installed can it damage the switch?
luis_cordova
Hi @dani_corunda,
According to the guide, all power supplies are compatible with your device model.
In addition, it is indicated that the power range that supplies the power supplies is autoranging.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750x_3560x/hardware/installation/guide/3750x_3560x_HIG/HIGSPEC.html
Therefore, I do not believe that the 1100 power supply will damage your device.
Leo Laohoo
Nope.
Deepak Kumar
No, it will not.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
