05-20-2024 10:31 AM
Hello Everyone, lets talk about the issue directly, i've 2 Cisco SWs
first one is:-
second one is:-
--> i'll upload the 2 SWs configuration files..
--> and also be noted that the exec-priv working well with the first SW "SG300-28PP 28-Port Gigabit PoE"
--> i belive its related to authorization or something likethat..
--> this image is the radius configuration "exec-shell attribute"
05-20-2024 03:19 PM
you have only posted priv 15, how about policy you created and confirming that user in different group
check below guide for reference : (also on switch have 2 configuration for radius, so remove that not to confuse)
https://blog.skufel.net/2012/06/how-to-integrating-cisco-devices-access-with-microsoft-npsradius/
05-20-2024 04:25 PM
Thank you for the reply but the other policy is the same as the provided one except for shell:priv-lvl=7. however i've tried the guide u mentioned but unfortunately it still gives me the same privilege 15 however im setting it to priv=7
any help please.
05-20-2024 04:26 PM
just another note it works like a charm on the other SW "SG300-28PP 28-Port Gigabit PoE+ Managed Switch"
