About Cisco 2921 netflow
chia hao chang
Hi all
2921 used 2 GE with sub-interface
1 serial and WAAS module
BR005#sh ip int brief
Interface                  IP-Address      OK? Method Status                Protocol
GigabitEthernet0/0         unassigned      YES NVRAM  up                    up
GigabitEthernet0/0.1       10.122.5.254    YES NVRAM  up                    up
GigabitEthernet0/0.2       10.222.5.253    YES NVRAM  up                    up
GigabitEthernet0/0.3       10.131.5.254    YES manual up                    up
GigabitEthernet0/1         10.13.5.253     YES manual up                    up
GigabitEthernet0/2         unassigned      YES NVRAM  administratively down down
Serial0/0/0                10.203.1.2      YES NVRAM  up                    up
In1/0                      10.205.15.2     YES NVRAM  up                    up
Loopback0                  10.24.24.5      YES NVRAM  up                    up
Tunnel0                    10.202.81.2     YES NVRAM  up                    up
Tunnel1                    10.22.11.2      YES NVRAM  up                    up
Tunnel2                    172.16.0.1      YES unset  up                    up
Tunnel3                    172.16.0.1      YES unset  up                    up
Tunnel4                    172.16.0.1      YES unset  up                    up
IOS version is c2900-universalk9-mz.SPA.150-1.M3.bin
I create 2 tunnel for WAN
and I want to monitor these tunnels traffic with cascade
my commands example is
interface Tunnel0
bandwidth 2048
ip address 10.10.10.2 255.255.255.252
ip mtu 1460
ip wccp 62 redirect in
ip flow ingress
ip flow egress
ip tcp adjust-mss 1420
ip ospf network point-to-point
ip ospf mtu-ignore
keepalive 1 15
tunnel source Serial0/0/0
tunnel destination 10.10.11.5
tunnel path-mtu-discovery
ip flow-cache timeout active 1
ip flow-export source Loopback0
ip flow-export version 9
ip flow-export destination 172.19.10.100 9996
I only config "ip flow ingress" and "ip flow egress" in interface tunnel
but in cascade report
it list all my interface
my old router is 2821, and never with this problem
so, something wrong with my configuration ?
thanks
umeshagroya
sa
