01-21-2015 11:27 PM - edited 03-07-2019 10:19 PM
hello,
i have a 1921 cisco router, and i would like to create VPN as well as implementing router-based firewall, but when i tried to accomplish that i found that some commands are missing from my IOS such as isakamp, ip inspect. so i did recognize that some features are not enabled and i need licencse to activate them. i issue the command show licence and show version and this is what i got :
Index 1 Feature: ipbasek9
Period left: Life time
License Type: Permanent
License State: Active, In Use
License Count: Non-Counted
License Priority: Medium
Index 2 Feature: securityk9
Period left: Not Activated
Period Used: 0 minute 0 second
License Type: EvalRightToUse
License State: Not in Use, EULA not accepted
License Priority: None
Index 3 Feature: datak9
Index 4 Feature: SSL_VPN
License Count: 0/0 (In-use/Violation)
Index 5 Feature: ios-ips-update
Index 6 Feature: hseck9
Index 7 Feature: WAAS_Express
Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.2(4)M5, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Fri 13-Sep-13 13:51 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
SPCC_Router uptime is 9 weeks, 1 day, 13 hours, 59 minutes
System restarted at 18:17:30 UTC Tue Nov 18 2014
System image file is "usbflash0:c1900-universalk9-mz.SPA.152-4.M5.bin"
Last reload type: Normal Reload
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO1921/K9 (revision 1.0) with 491520K/32768K bytes of memory.
Processor board ID FCZ180992VH
2 Gigabit Ethernet interfaces
1 terminal line
DRAM configuration is 64 bits wide with parity disabled.
255K bytes of non-volatile configuration memory.
249840K bytes of USB Flash usbflash0 (Read/Write)
License Info:
License UDI:
Device# PID SN
*0 CISCO1921/K9 FCZ180992VH
Technology Package License Information for Module:'c1900'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security None None None
data None None None
Configuration register is 0x2102.
please i need some details how i activate my router or any other solution to get what i am attempting to perform.
any kind of help is greatly appreciated.
01-22-2015 12:52 PM
You need securityk9 for those features. You can activate an eval licence for securityK9 with the command "license boot module c1900 technology-package securityk9".
