Access a router using a switch. Is it possible?
fabio.marino
Hi, i'm Fabio and during my CCNA exam simulation i got the following question, but really, i diin't get what the problem is.
I have a topology  like:
PC -> swicth -> Router.
Following, the swicth configurations:
interface Vlan1
no ip address
shutdown
interface Vlan2
ip address 192.168.2.2 255.255.255.0
line con 0
line vty 0 4
password cisco
login
line vty 5 15
login
Following the Router configuration:
interface FastEthernet0/0
  ip address 192.168.1.10 255.255.255.0
  duplex auto
  speed auto
line vty 0 4
password cisco
login
Router uses its FastEthernet 0/0 to communicates with switch.
So, whenever i try to telnet the router from the swicth (S# Telnet 192.168.1.10) all packets are dropped, but i was not able to understand the problem. Thanks in advance, king regards Fabio.
Jon Marshall
interface Vlan1
no ip address
shutdown
interface Vlan2
line con 0
line vty 0 4
password cisco
login
line vty 5 15
login
  duplex auto
  speed auto
line vty 0 4
password cisco
login
Fabio
Is you switch a L2 switch or a L3 switch ?
If it is L2 then you either need to -
1) have the vlan interface, vlan 2 in your example, in the same subnet as the router or it won't work
or
2) setup a trunk on the switch and use 802.1q subinterfaces on the router. The router would then need a subinterface for the vlan 2 subnet.
Jon
shahhardik
Hi Fabio,
For your requirement you need to allow Telnet on line vty, but before that first check the PING response from the switch, whether r u able to ping or not, if not. Here you also need to configure Default gateway in your switch as 192.168.2.2. After that configure below command in your configuration.
On Switch: Switch#config ter
                 switch(config)# line vty 0 4
                                     # transport output telnet ( This command is to allow outbond telnet, which you require to telnet your router)
                                     # transport input telnet   ( This command is to allow inbond telnet)
On router: router# Config ter
                        # line vty 0 4
                        # transport input telnet ( This command is to allow inbond telnet, which you will require when you try to telnet from switch)
Hope this will work fine.
Hardik
Thanks Hardik, but i tried your suggestion and it doesn't work.
I'm able to ping and to telnet the FastEthernet router interface form the PC, but i'm not able to ping the same interface from the switch.
I'm no able to fix the problem but i think that something is wrong with the FastEthernet switch interface direct to the FastEthernet router interface.
First of all, tha FastEthernet router interface has a 192.168.1.10 ip address.
The PC NIC interface of the host has a 192.168.1.88 ip address. What about the ip address of the switch FastEthernet interface direct to the router? (Topology: PC->switch->Router)It doesn't have ip address,so,  when i try to ping the router from the switch, the ICMP echo request packet leave the switch,  doesn't have ip address in the source field and i  think this is the reason why ping doesn't work, more, the router doesn't know to who send back the ICMP echo reply. The same think for the telnet session. I think that to obtain this i need to configure the switch interface direct to the router as a routed interface (no switchport) but this is feasible only in L3 swicth, and is not my case.  Any idea? Is it right my throubleshoot? Thanks in advance, Fabio.
Jon Marshall
interface Vlan1
no ip address
shutdown
interface Vlan2
line con 0
line vty 0 4
password cisco
login
line vty 5 15
login
  duplex auto
  speed auto
line vty 0 4
password cisco
login
Fabio
or
Jon
Thanks, now it all works (my switch is L2 switch).
Here my task:
1)I changed the ip address of the vlan 2 interface of the switch in order to be in tha same network of the router and host.
2)The fastethernet of the switch direct to router was set in trunk mode, and vlan 2 was set as native vlan
3)At the router interface direct to the swicth i created a subinterface Fa0/0.2, i fixed the encapsulation as dot1q, with native vlan2 and with ipaddress in the same network of the vlan 2 interface of the switch and host.
Thanks, regards Fabio.
