Access Control Lists
shane.kearney
Level 2
Level 2
ok I know about the 5 different acls and the basics of how they work, but what gets me is how to restrice some ip addresses from getting access like
192.168.1.0 0.0.24.255 or something like that, how is this worked out
matej.polak
Community Member
this is so called wild card mask. To make it as simple as possible, it is the opposite of the network mask.
Example:
if you want to deny this subnet: 192.168.1.0 255.255.255.0
you have to use this wild card mask: 0.0.0.255
The formula to calculate the wild card is:
255.255.255.255 - subnet mask = wild card mask
255.255.255.255 - 255.255.255.0 = 0.0.0.255
In subnet mask the 1 bit must match and 0 is ignored.
In wild card mask the 0 bit must match and 1 is ignored.
