Access-list Permit and Deny for SG300-10 Switch, ACL
rkent649649
Good morning, I have a Cisco SG300-10 10Port Gigabit Managed Switch that is set to L3 Mode. I have set 2 vlan (vlan 30 and vlan 40) and set a static route from our firewall so the vlan can connect to the internet. Now as I go further, I would like to make vlan 30 inaccessible by vlan 40 while vlan 40 can be access by vlan 30 and at the same time both vlan would have an internet connectivity. As I searched for this, I came across with ACL, and tried to configure the switch. However, during the process, what happened was, both vlan can no longer access with each other but there is still an internet connectivity for each vlan.
For my current switch running-config, please do see the information below.
config-file-header
Switch
v1.3.5.58 / R750_NIK_1_35_647_358
CLI v1.0
set system mode router
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
vlan database
vlan 30,40
exit
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
ip dhcp relay address 192.168.20.254
ip dhcp relay enable
ip dhcp information option
bonjour interface range vlan 1
ip access-list extended Dot30
permit ip 192.168.30.0 0.0.0.255 192.168.20.113 0.0.0.255
deny ip 192.168.30.0 0.0.0.255 192.168.40.0 0.0.0.255
exit
ip access-list extended Dot40
permit ip 192.168.40.0 0.0.0.255 192.168.20.113 0.0.0.255
permit ip 192.168.40.0 0.0.0.255 192.168.30.0 0.0.0.255
exit
hostname switch
clock timezone " " 0 minutes 0
clock dhcp timezone
interface vlan 1
 shutdown
interface vlan 30
 ip address 192.168.30.1 255.255.255.0
interface vlan 40
 ip address 192.168.40.1 255.255.255.0
interface gigabitethernet1
 service-acl input Dot30 default-action permit-any
 switchport mode access
 switchport access vlan 30
 switchport forbidden default-vlan
interface gigabitethernet2
interface gigabitethernet3
interface gigabitethernet4
interface gigabitethernet5
 service-acl input Dot40 default-action permit-any
 switchport access vlan 40
interface gigabitethernet6
interface gigabitethernet7
interface gigabitethernet8
interface gigabitethernet9
interface gigabitethernet10
 ip address 192.168.20.113 255.255.255.0
exit
ip default-gateway 192.168.20.254
Please do note that the ACL configuration was done using the web GUI for I keep on having error like unrecognized command if I'd go for CLI command. Hoping for any help from you guys. Thank you very much in advance.
Mark Malone
Hi you could try this
conf t
permit ip 192.168.30.0 0.0.0.255 192.168.40.0 0.0.0.255 -------permits vlan 30 to speak to 40
deny ip 192.168.40.0 0.0.0.255 192.168.30.0 0.0.0.255----------denys vlan 40 from speaking to 30
exit
remove extra acl no need
conf t
no ip access-list extended Dot40
exit
apply it to all ports as its sg300 dont think you can do vlan ip access group
interface range g1 - 10
heres the admin guide may help
http://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/sf30x_sg30x/administration_guide/78-19308-01.pdf
Thank you for that. By the way, for the default action, in service-acl command, do I need to put permit any or deny any? I've tried deny any, and what happen is when i connect a host to vlan30 or vlan40, it losses connection and can no longer generate IP from the DHCP.
Hi rkent
I dont know if your switch supports Reflexive ACLs but you can deny traffic from one direction and allow opposite direction with help of Reflexive ACLs  (Behind ASA's inpection was Reflexive ACLs )
http://www.cisco.com/c/en/us/td/docs/ios/12_2/security/configuration/guide/fsecur_c/scfreflx.html
Hi Mark
I have two questions:
1)What is the difference between 2 ACLs and 1 ACL (which covering both)?
2)if switch permits vlan 30 to ping 40 but deny opposite . Then  when I ping from 30 to 40 , icmp is permitted but in order to ping be succesfull  from 40 to 30  echo-reply has to come. So switch will block echo-reply which comes from 40 to 30 . Theoretically the idea of permitting traffic from one vlan to another and denying opposite way is not possible and if it works then how?  ASAs has security levels and it has this kind of function but ASAs has inspection and its more capable device than switch.
