Accessing inside LAN resources with their public IP
AHMADJ
please note i have cisco 2921 router for expertise can you provide me configration to access lan servers from outside
below is connectivity diagrad
cisco 2921 port gig0/0-------------------connected to wan with puplic ip (x.x.x.x y.y.y.y)
cisco 2921 port gig0/1-------------------connected back to back LAN server with private ip ip (10.0.0.1 /30) server ip 10.0.0.2/30
brselzer
Do you already have NAT configured on the device? If so, you should just be able to add a static NAT statement like so:
ip nat inside source static 10.0.0.2 interface gig0/0
Or even better would be to lock it down to a particular port so that all traffic doesn't go to the server:
ip nat inside source static tcp 10.0.0.2 80 interface gig0/0 80
The above would allow port 80 through but nothing else.
Hope that helps!
-Bradley Selzer
CCIE# 60833
